blue er
thanks time to start savingShootinstick
Allen,
Great video of the Power Commander installed and in use. I notice in all the pics of the dash you have a Fault Code 13 (Air Pressure Sensor) showing. Is this a side effect of the Power Commander or do you have it disconnected on purpose? Also I sent you an email regarding TPS angle adjustments but have not received an answer.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Shootinstick, the reason the Fault Code 13 is because this sled has a bad Air Pressure Sensor, that is not anything to do with the Power Commander setup. I have not received your email. Please send it again Srxspec@Gwtc.net!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
hey guys...im starting another thread with the DOO wheel brackets...
Dan
Dan
SharkAttak
Dan, if you on the ice today, try and report how you made out with top end #'s
SharkAttak
so with the 2 programmers what rpm is the peak h.p. now
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
SharkAttak said:so with the 2 programmers what rpm is the peak h.p. now
I pulled ALL my tip weight out of my DPYRs and on the ice i can only pull 10,700 or so....not sure why but i hoped to rev it at 11,000 now....
Im not sure if the mild temps did it or the ice?....she will rev close to 11 on snow though
went riding,so i didnt get anymore radaring in today.....
Dan
SharkAttak
ROCKERDAN said:SharkAttak said:so with the 2 programmers what rpm is the peak h.p. now
Dan
i just wondering what the peak h.p. powerband is now with all the toys on it, the plugs,ram-air and programmers, peak h.p. was between 10,200 & 10,800, what will it be now? 11,000?
SledFreak
- Feb 7, 2005
- Ontario. Canada
He's about 160-163. Peak Power @11,000-11,200RPM is where he wants his clutching to work well on the big end.
SharkAttak
SledFreak said:He's about 160-163. Peak Power @11,000-11,200RPM is where he wants his clutching to work well on the big end.
nice
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
bringing this thread to top for another member to see...
Dan
Dan
GotJuice
Great read!
Love the Avatar...sick bike man! Has anyone tried this set up with the cams from Hauck or Racin station and higher compression by splitting the head gasket and porting the intake/head to see what can be the total achieved? I know a few guys talked about this in the past but never seemed to hear the end result......Nice work man looks great!
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
thanks.....
havent followed much on that.....i know im leaning toward MPI boost for my 06 rtx....too many people having too much fun with boost,and i dont think there is much more to be had without boosting these motors.
BTW...my pc3/ign module should be for sale soon.
Dan
Dan
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
- moncton new-brunswick
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
It allows the tuner to add or remove ignition timing from the base ecu setting. Just like the pc3 allows you to add or remove fuel from the base setting.
