carcus1
- Oct 30, 2016
- manitoba
- ventures
Just noticed a sticker on my venture lite today that said to use 91 octane, ive been using regular, what is everyone using here?
Sent from my SM-G930W8 using Tapatalk
YukonMP
- Dec 25, 2014
- Yukon Territory
They are fine on regular. I use premium because there is ethanol in the regular in this area.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Same here. If it were to knock, it will retard the timing with loss of some power. That's what the KCS light is for.
Ethanol is just bad. BTW, all Petro-Can grades has ethanol, even premium.
carcus1
- Oct 30, 2016
- manitoba
- ventures
Thanks guys
BACK COUNTRY YAMAHA
- Nov 26, 2015
- newfoundland
- 1997 vmax 600 sx, 99 venture 600, 2004 vk 540, 2006 Yamaha vk pro, 2009 venture multi purpose and 2006 venture 500 xl current ride 15 rs viking pro
I use premium fuel as suggested, the 500 engine is producing a lot of power given the displacement, the knock sensor is a fail safe in case of bad fuel or if premium fuel is not readily available. basically the same as the newer apex engines that require the use of premium fuels. It's your preference, your sled! cheers!
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
regular is fine, you may or may not be giving up a few HP. There are 2 stages to the DCS and the first stage doesn't light up the light, just retards the timing a small amount for a lit bit. The second stage pulls a lot of timing and lights the light up. 6000+ miles with 75% of that 87 E10 and I've never had the DCS light come on.
