Dr. FeeLGooD
I have a black mark all around the top of my primary the width of the belt. I do mot have the top end I should have. Completely stock 2019 xtx le 141. I am thinking a stiffer spring or maybe heavier weights. Or both. I am no clutch guru. What do I need to fix this? about 1000 miles on it and one blown belt at about 450 miles a few miles after I was stuck in the deep.
Baydog
I would clean my clutch and try a fresh belt first before I started changing clutch components.
Fleecer
- Jun 13, 2014
- 2019 SRX
Yamaha put a pink spring in the secondary for 2019, which I think sucks.
You can try winding it tighter or put either Yamaha white or Dalton black/orange.
Dr. FeeLGooD
As I was poking around wondering what to do it looks like the secondary does not float. New for 2019? I am also thinking spring is too soft. Ya, I am going to clean both clutches. Same puller as my Nytro?
Fleecer
- Jun 13, 2014
- 2019 SRX
Secondary only starts to float when belt sinks into clutch. Sink belt like going to remove and should float.
Nytro puller will work.
AAD
- Dec 11, 2018
- SRX
Does your primary spring have the paint worn off on the sides in places by chance?
Fleecer
- Jun 13, 2014
- 2019 SRX
Normal wear and tear!
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2018 High Country 9000
2001 SRX 700
Do you have black marks in the secondary as well? My sled is similar to your and I had to put a stiffer secondary spring.
Dr. FeeLGooD
Secondary looks ok. What spring did you install and how do you like it?
1049triple
- Jan 19, 2009
- Pohenegamook, Qc
- 2025 SRX
2001 SRX 700
Currently running the EPI purple at 0-1. Really like it. Keep the RPMs right where they should be. Good snap too. But I do not have tested back to back tests with others since I use this one.
- 22K
