PowderFalcon
Pinnin' it!
Which primary puller are you guys using? Bought one from the dealer last year. First use and it got bent to rat #*$&@ before the clutch finally popped. Luckily the dealer took it back.
Thanks in advance
Thanks in advance
same one as you and i have bent a few of them. best trick is to fill the clutch bolt hole with grease before using the puller. usually does not bend that way but i have had to cut a clutch off because i bent a puller that way.
