boostedmayhem
- Dec 22, 2015
- idaho
- 2006 yamaha apex turbo.
2024 polaris khaos matryx slash boost
Im having problems at around 9k rpm on up, the issue is at that point it starts to drop power stutter and pop, figured it was a tuning issue but I cant seem to get it cleared up. Im hoping its not something major, im running a boondocker side mount turbo with the boonbox, it has corillo rods and je pistons, msd fuel pump, big injector kit and garrett gt2871r turbo. Any help would be appreciated.
Zuki1216
- Dec 9, 2015
- Indiana
- 08' Apex LTX
07' Attak MPI S/C
AFRs?
Sent from my SM-N910V using Tapatalk
Jory
- Mar 20, 2016
- Alberta
- 2007 Phazer MTX SC
Worn ignition coils will cause that issue, could possibly be spark blowout and a couple other things.
Need AFR numbers?
boostedmayhem
- Dec 22, 2015
- idaho
Afr is right around 12 -12.5
When it start to act up, does the AFR start to go fat?
boostedmayhem
- Dec 22, 2015
- idaho
No it may go up or lean by .5, most of the time at wot its at 11 to 12.8 at the most
boostedmayhem
- Dec 22, 2015
- idaho
For some reason I have a feeling it has to do with the boondocker control box, possibly settings wrong somewhere.
boostedmayhem
- Dec 22, 2015
- idaho
Ive been looking at getting the motec standalone, what are your thoughts on going with the motec?
I have never used them. I am sure its a setting thats causing this. I know on my Super Charger with PCV, I was having all kinds of a problems with the Throttle Body Vacuum sensor. Try unplugging the sensor on the top of the rack, it will thro a code but it wont hurt anything.
boostedmayhem
- Dec 22, 2015
- idaho
Ok I will give it a try, thank you much for the help, I will let you know the results.
boostedmayhem
- Dec 22, 2015
- idaho
Not sure if this will help, but here are the current settings
3000 -01 -03 00
6000 00 -05 00
8500 00 -05 00
10k5 00 00 00
Acel. AM DR N2 DL
01 03 00 00
Tbol -4 -2 +4 +8
00 00 20 40
Tboh 12 16 20 24
60 80 100 120
3000 -01 -03 00
6000 00 -05 00
8500 00 -05 00
10k5 00 00 00
Acel. AM DR N2 DL
01 03 00 00
Tbol -4 -2 +4 +8
00 00 20 40
Tboh 12 16 20 24
60 80 100 120
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
How much boost?
Zuki1216
- Dec 9, 2015
- Indiana
- 08' Apex LTX
07' Attak MPI S/C
Good question.... Severe detonation?How much boost?
boostedmayhem
- Dec 22, 2015
- idaho
Currently only running around 8-10#, also running sunoco 112
- 6K
