I had and issue with a family of mice living in my throttle bodies (6 mice that I took out with needle nose pliers no longer need a place to live ) the throttle bodies were trashed and when replacing them and cleaning intake runners and valves I found the support brackets for the rad. on both sides toward the front of the sled connecting to the frame were broke completly off. they were replaced under warr. when changing out I broke off the remaing good leg on the broken bracket and added it to the new bracket front leg with a pop rivet to give it more support 1500 mls on my sled with average riding you folks might want to check these once in awhile.
NyTrOMaNIaC
I read this in another thread too. Perhaps someone can post up a pic of what and where to look, because I checked mine over and I didn't notice anything out of the ordinary. Thanks for the heads-up
rsmiller17
I heard that if you park that Yamaha next to an Arctic 'Cat' you wouldn't have that problem!!!
NyTrOMaNIaC
rsmiller17 said:I heard that if you park that Yamaha next to an Arctic 'Cat' you wouldn't have that problem!!!
Well maybe that's why mine is fine...
Still like to see some
- 17K
- 28K
