Ram Air Mod Details
YamaMissle
Elliot State Park, PA
I've been reading all the past posts on the ram air mod from Rockerdan. I've made the cut outs to the airbox lid and ordered the prefilter, but need help with how to make the prefilter "frame" and attach it to the airbox. Any info or pictures would be greatly appreciated.
frame
Not shure if this helps, the frame is attached to the lid with small screw's
Thanks!
Thanks for the fast responces. Rockerdan, I must have read your post above 50 times but the pictures never showed up on my screen. . . untill I signed up as a site member. Now it all makes perfect sence. Can't wait to try it out. If you coud just send some snow my way! :letsnow:
Re: Thanks!
yes you need to be logged in to see any attchments....glad you got it worked out!
Dan
How much noisier those it make it, is it something anoying after a full day of sledding, those your ears get all DRONNED in your helmet...
sound
I like it, when you pin the throttle you can notice it but when rideing you cant. Sounds good to me. :Rockon:
it only is loud when you crack it,and its nothing compared to my open pipe Vrod..lol
for the single biggest MPH ADDER,i dont care what it sounds like....its a must have IMO.
plus i LOVE the sound!
Do you have to re-map, you'll probably have a LEAN spot in the rpm range...
no remap.....ECU adjusts,similar to how it will adjust on the new yamcharger.
However,im guessing my Pc3/ign module can make the ramair make even more HP then stock ecu does.
Dan
Just finished the ram air mod. Rockerdan's pictures were super helpful. So glad I did this mod myself. Wasn't hard, just took some time and patients. Had my wife do the stiching. turned out great and saved tons of money. Thanks to all! Remember. . . anyone who's going to try this, make sure you sign up as a site member or you can't view the step by step photos.
