showtime
- Sep 16, 2016
- New Brunswick
- 09 turbo cat
What worked for my 137 zr lxr was a set of the fiberglass overloads off the Pantera ,when putting a 2 up seat on and luggage i just flip the block up and good to go,just a thought
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
the 4th position on my adjuster blocks is an overload that adds approximately 1/2" more preload over the stiff setting on stock adjuster blocks. Simple swap out.
Derailed
Here the actual listing in the tech book for u, so u probably want the 22 lb ones
Thanks this is exactly the info I was looking for. The springs don’t weigh any where near 20lbs so spring rate makes sense now.
I have a 2016 Viper RTX DX and a 2017 RTX SE sidewinder both 129”. I took the springs out of both. Interestingly, the Viper has one 85deg spring and one 90deg spring. Sidewinder has both 90deg springs. Which probably explains why I found the Viper to have better ride height.
I’m going to order 2 of the heavy springs and will see if I still need an adjuster when saddle bags are fully packed.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Damn. I’m 300 and only noticed the center spring on large hits.
Derailed
What model do you have? It seems there might be a correlation with the 129” being softer.
Good chance these will be less expensive to buy through Cat.Thanks this is exactly the info I was looking for. The springs don’t weigh any where near 20lbs so spring rate makes sense now.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
129
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Ok reviving this. Anyone know the part numbers? Been struggling to find other options.
Turboflash
- Mar 18, 2019
- Southern MN
Might want to check out Cat RR springs. They're probably stiffer.
No. Same as stock Viper Rtx springs.Might want to check out Cat RR springs. They're probably stiffer.
Here you go
ty4stroke.com
Spring Charts
Been Playing with Springs. Far as I can tell all models have same rear arm springs Yamaha#8JP-G7474/473 this is the same as AC#1704-576/577 I have tried and found the AC Lighter option #1704-354/355 to offer a softer ride on small stuff. Still testing on big. It did give me about a inch of...
1704-560,561 Would be heavier
Here is from 2022 Technical Manual For Sidewinder LTX SE
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
137 and the 129 the same torsion spring? As far as leg lengths?
- 31K
