They were very expensive.And the srx spring is $160 compared to the ltx spring which is $90
What issue are you having Fabio?And the srx spring is $160 compared to the ltx spring which is $90
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Ha ok.. no problem. I’m not having any sag issues with my sled but just wondering why some are having issues.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Though I will be sending you my shocks once I have the chance to pull them out.
If I had this issue I would be pulling both torsions. The short end should be at 90 deg to the long end. If its like the other its SRX springs. But ride it first. Maybe you will like it. Can also try softening the ski springs like SwampCat did.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Took 2 more turns of preload OFF of the ski springs and ...... most all of the dead sag is GONE.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
This gets better. Standing behind the sled, push down on the bumper and watch the suspension movement, the skid slides in the track. Playing with it more today noticed the front spindles cocked back and the skis went forward, then when I let off the bumper the sled moved forward about 1/2". I thought I was seeing things. So pumped the bumper a bunch of times and the sled CREEPS forward every time. Had to sit down and get something to drink and think about this one.
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
This gets better. Standing behind the sled, push down on the bumper and watch the suspension movement, the skid slides in the track. Playing with it more today noticed the front spindles cocked back and the skies went forward, then when I let off the bumper the sled moved forward about 1/2". I thought I was seeing things. So pumped the bumper a bunch of times and the sled CREEPS forward every time. Had to sit down and get something to drink and think about this one.
Russ....does it look anything like this when you push down the rear bumper?
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Thats the PERFECT description , the 1/2" worm. And NO we wernt drinking Tequila.Russ....does it look anything like this when you push down the rear bumper?
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
any idea how much the transporter spring is ?And the srx spring is $160 compared to the ltx spring which is $90
WinderFab
- Mar 1, 2009
- Woodbridge, ON
According to online partsany idea how much the transporter spring is ?
8ND-G7474-00-00 $242. Can
8ND-G7473-00-00 $236 Cdn
Not sure why right side is more $$$.
Not cheap by any means..
Holy Cow! Look up 129" springs from a 14 Viper or 7000 Cat. They are also much stiffer. Cheaper too I bet.According to online parts
WinderFab
- Mar 1, 2009
- Woodbridge, ON
I will..Holy Cow! Look up 129" springs from a 14 Viper or 7000 Cat. They are also much stiffer. Cheaper too I bet.
Since January 1st Yamaha Canada raised their prices on all parts and accessories quite a bit, at least here in Canada..
WinderFab
- Mar 1, 2009
- Woodbridge, ON
2014 viper rtx springs.. $108 each
8JP-G7474-00-00
8JP-G7473-00-00
8JP-G7474-00-00
8JP-G7473-00-00
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Yamaha wants $79.95 for the knee pads and Cat wants $49.95 for the same thing. Go figure...I will..
Since January 1st Yamaha Canada raised their prices on all parts and accessories quite a bit.
Sorry off topic but Cat prices seem to be way cheaper than Yamahas.
