Froggy
- Apr 29, 2016
- Kipawa,Quebec
- 2020 Winder LTX SE 17600 km and counting
2016 Viper LTX LE 23986 km sold
2015 Viper LTX DX Wife's 22500 km sold
2010 Vector LTX GT 25000 km sold
2024 SRX Leftover 3700 km
I'm looking for advice for setting up my suspension on my new 2020 LTX SE winder. The rear suspension is sagging and will not spring back up like my 2 LTX Vipers. I turned the springs adjusters to the stiffest setting and that did very little to help. I'm bottoming out and when you go top up the fuel tank by pumping the rear suspension it is already sitting on the rear arm shaft and the front suspension starts to extend. When you look at the track there is less than half the track is touching the ground as compared to almost over 3 quarters for the Vipers.
The dealer replaced the rear shock and dropped the front of the skid to the bottom hole and lowered the rear of the skid to the top hole on the brackets at the rear and now I hear the track hitting the rail tips on small rollers at low speed and I also hear the track ratcheting when using the brake to stop.
What should I do as I never had a problem with the Vipers should I put back the rear skid back to where it was and start lowering the preload on the front shocks to get the front of the track down more. plus the limiter straps are at the longest setting already. Looking for some help as I still have a couple of weeks to go sledding by the looks of the weather forecast.
Thanks everyone.
Thanks everyone.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
I'll assume the front half of the track is off the ground. Do you have your ski shocks set stiff? Limiter pulled up?
Froggy
- Apr 29, 2016
- Kipawa,Quebec
Yes as stated the front half off track is off the ground, limiter straps at longest and 2 inches of preload on front shocks as factory set.
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Jack up the free not till the skis are off the ground and loosen the spring retainers on the front shocks till the barely holt the spring in place and give them 2 full turns, that should drop the front end, I would do this first. 2” of preload is crazy. I have a 17 ltx le and I think the front mounting hole of the rear suspension is in the upper hole and so is the rear. Not sure with the new 20 rear suspension but could be binding or something weird if the geometry is off
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
With the '20 ARCS suspension, the rear suspension bolt needs to be in the lower hole. And yes, first start by loosening the ski shocks.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Just brought home a 2020 LTX-GT. Rear is the SAME way. Its sitting on the rear axle, then there is a increasing gap all the way up to the rail bend. About 1 and a half inches, I will measure it later. This is sitting on a flat floor. Also noticed the front arm with the slider slots is bottomed out aginst the rubber dampers. I did have the front of the sled jacked up about a foot when I noticed that though, will let it down and check again.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I believe the spring are bad. Seems like a bad batch of torsion springs. I know that sounds crazy but this is one of many complaints about the sled sagging badly in the rear. IMO the torsion spring are JUNK. Seems the 20’s had a bad batch
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
It could be but my 2020 ltx gt hasn’t given me any rear suspension problems, I have my cam adjuster on softest and compression knob on 1 since day one.I believe the spring are bad. Seems like a bad batch of torsion springs. I know that sounds crazy but this is one of many complaints about the sled sagging badly in the rear. IMO the torsion spring are JUNK. Seems the 20’s had a bad batch
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
You got good torsion springs. I don’t believe it’s every sled in 20It could be but my 2020 ltx gt hasn’t given me any rear suspension problems, I have my cam adjuster on softest and compression knob on 1 since day one.
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
How bout you saggy pants post photos for review? Seems it most only be the torsion spring.
Froggy
- Apr 29, 2016
- Kipawa,Quebec
Well I put the rear suspension back to the factory holes and I loosened up the front shock springs until they were loose and then I turned in the lock rings 2 1/2 turns and I noticed an improvement. When I said that there was 2 inches of preload that is how much thread there was above the lock rings, There was actually 7 turns of preload on the front shock springs prior to me loosening them. The skid looks a lot more level and the track is almost touching at the front idlers. The rear still doesn't return to full height after compressing the skid and it takes almost 400lbs at the bumper tunnel area to fully bottom out the suspension to the bump stops. I did fiddle with the rebound adjusters in the front shocks to the midway point and I'll finish the year around these settings front and back for the time being. Thanks for the help everyone and I'm going for a lunch run tomorrow in the 320-400km area depending on my direction of travel.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
But does it sit FLAT on the floor. Just measured mine the gap under front of track was 1". Also had a LOT of preload on front ski shocks. Ended up with 4 1/2" of thread on shock body. Gotta start somewhere.It could be but my 2020 ltx gt hasn’t given me any rear suspension problems, I have my cam adjuster on softest and compression knob on 1 since day one.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Last time I had it in the shop it was sitting flat on the floor.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
You should remove most of the preload out of the ski shocks. Jack the front end up, loosen the spring retainers till the spring can move, then snug the retainers 2 full turns starting with zero preload.But does it sit FLAT on the floor. Just measured mine the gap under front of track was 1". Also had a LOT of preload on front ski shocks. Ended up with 4 1/2" of thread on shock body. Gotta start somewhere.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Thats what I did, how I ended up at 4 1/2" of thread.You should remove most of the preload out of the ski shocks. Jack the front end up, loosen the spring retainers till the spring can move, then snug the retainers 2 full turns starting with zero preload.
- 10K
