Big Pussy
- Apr 12, 2016
- Woodstock, Ont
- 2015 XF7000 LXR
I have no faith in that fuel line, filter and clamps. I tossed the whole assembly for a new molded assembly from the fuel pump to the injector rail. No hose, no filter, no clamps period. I got a Cat part from the last year they built a 7000. I imagine the Viper has the same part. Over the years, they had 3 different hose assemblies. The last one looks like automotive quality so I hope it has some more design thought than the 14 - 15 junk.
Dang. Didn’t know that and ordered 19 alreadyI have no faith in that fuel line, filter and clamps. I tossed the whole assembly for a new molded assembly from the fuel pump to the injector rail. No hose, no filter, no clamps period. I got a Cat part from the last year they built a 7000. I imagine the Viper has the same part. Over the years, they had 3 different hose assemblies. The last one looks like automotive quality so I hope it has some more design thought than the 14 - 15 junk.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Sure will, I'm trailering early Friday morningI cut the hose cleaned filter and replaced the clamp for this weekend. New 2019 hose which no longer has the filter should be here by Fri or Mon. Was 5 in WI. But old one needs to make the weekend. Double clamps is a good idea! She is all buttoned up and ready to go though. Hey are you going to Muni Fun Ride this weekend? Hope so. We are riding sleds there from Pembine.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I must have missed the recall or something... are there particular midel years Vipers that this applies to, or do all Viper owners need to check condition of fuel lines?
I believe it was just 14-15I must have missed the recall or something... are there particular midel years Vipers that this applies to, or do all Viper owners need to check condition of fuel lines?
Perrdog
I did a filter change at 5k didnt leak till after summer storage.just tightened.all good...for now
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I had a 2015 SR Viper MTX with 16 miles on it burn to the ground after that hose leaked! Buy the updated part number 8NF-F4310-00-00 for $34.99!
2015ViperMTX
Does the 8NF-F4310-00-00 eliminate the fuel filter? I don’t see the filter on the fiche when looking up that new part number
- Apr 17, 2003
- Menno, SD
- Menno, SD
Yes it eliminates the filter, there is no external filter needed. There is a filter in the tank on the pump.
I did. On its way. Hopefully that PN!I had a 2015 SR Viper MTX with 16 miles on it burn to the ground after that hose leaked! Buy the updated part number 8NF-F4310-00-00 for $34.99!
Perrdog
Yep me too,thanks
Big Pussy
- Apr 12, 2016
- Woodstock, Ont
- 2015 XF7000 LXR
The Arctic Cat part number is 1770-200 for 33.95 Canadian. It is from an 18 or 19 7000.
This is a molded plastic fuel lie with the O ring pump end and the O ring fuel rail end all molded on. No clamps, no filter. Nothing to leak, I hope.
Clyder6R
- Dec 24, 2015
- Atlantic Canada
- 2015 Yamaha Viper MTX 153 McXpress 190 kit
got itI replace my whole 2015 line and filter with a new molded assy. from a 19 if I remember correctly. $35 cdn. I caught it dripping on the heat shield too.
Great news! Even though I ordered older fuel line Yamaha must have done right thing and threw out the old stock. Got plastic line with no clamps. Made me so happy I got a set of the Stryke skis ordered and shim kit. Blue with white loops.Can’t wait to try them when in! Thanks Big Pussy!
2015ViperMTX
I ordered #8NF-F4310-00-00 because that was the part number mentioned above
Hopefully I get the correct one
