Regular 87 (10% ethanol) vs Premium 91+ (ethanol free)
Oh Come on RIGIDONE how can you play this loosening game, So know it has to be exact amounts, well in the real world how do you now how much fuel & water is in your tank and how much MIB to add.
You have got to be kidding me that I must use exact amounts of water-fuel-MIB for TRICK to work, tryed being nice.
SNAKEOIL-SNAKEOIL-SNAKEOIL
I never said exact amounts, but there has to be enough fuel to bond the molecules..There is a reason your container is so cloudy, because the molecules are not bonding, the are fighting each other..separating..its not that hard to figure out..
Did you do the burn test???
Rig I could care less about the burn test.
I ain't gonna run sled on fire!
I repeated your test and it FAILED.
Iam solo tired from all this testing I need to take a nap. Let's call it a TRUSE.
I have learned what I needed to.
I dont know what you did bigdog, but I just did it, as you can see, this thread is in the back ground.. my end product is clear, zero separation.. product works as i said..It's really easy to do, but there has to be enough fuel and MIB to bond everything..
Another member just texted me saying he has BEANS that you put in tank and swears you go 15mph faster.
Geez I might as well test them too.
Oops must wait for snow on that test.
Not sure what he was telling you but I have these that you can put in your tank when not ridding (I use it in the off season). It absorb any water in the fuel. Lots of different brands out these.
Well I used more fuel and MIB than you did with small amount of water.
And like I showed will separate after 2-3 minutes. Back to my nap now.
I used 2ml of water, 20ml of MIB and well the fuel, I dont know the amount..But my test confirms what I said it does..Its still not separated, keeping the bottle as it is for a few days, where it sits, will be taking pics daily..I think you should do the test 1 more time..If its cloudy, there is not enough MIB, so just add more MIB a little bit at a time. you will see a change when it meets the correct ratio to bond everything..
So I guess you need to drain tank every day and mix this witches brew and then pour it in sled, not practical
AND JUST FOR YOU I ADDED ANOTHER .5OZ OF MIB in my jar and shook it up and 2min later it separated.
Heck maybe I got a BAD Batch of MIB.
My testing is done and my conclusion is made, to each his own.
odd, mine is still just chilling, totally clear, nothing separating..everything is bonded and happy..:Rockon: Been 30min already....try tossing a bit more MIB in..like I said, it has to reach a correct ratio..
Well in my 12oz? Of fuel I have 1oz of MIB, If I put more ratio than that I couldn't afford to ride sled.
Bottle says 1oz per gallon if running poor
Iam 1oz to 12oz of fuel.
Iam wore out by this back and forth crap
Please let me rest up from all this snake oil testing.
LOl, well my best guess is I have about 5oz of fuel in my bottle, about 1oz of MIB (20ml) and 2ml of water..and she is still clear, and not separating.. it's been over 2 hours..
I find it odd that you claim It's snake oil??, it's fully synthetic, no petroleum products in it at all and still working as as I said..Dont get pissed off because you did something wrong when you tried it.. If you blew up a chain saw that was supposed to have a mix of 20:1 and you ran 50:1, who's fault is that?? is it a shitty chain saw??? or operator error.. Don't shoot the messenger..
Ok now let's get F**KING real you're sounding like a fool.
We ain't talking about a 2stroke chain saw:::we're talking about dumping your #*$&@ in the tank of a 4 stroke sled and fixing the water problem.
You say 5oz fuel to 1oz MIB.
Add that up in a 300 mile weekend and you'd be broke at that ratio.
The damn bottle says 1oz MiB per 5gal fuel---- that's not your medicine show test.
well lets not sound foolish, my ratio was to reverse phase separation, as stated in the video we used specific amounts of water and fuel to create phase separation and a specific product to reverse it... you said "i did it exactly like the video"..you admitted you used the wrong product, not what we used in the video, you used different amounts of everything and then come back on here and bash???
You would only have to use the ratio I used in a weekend if you were purchasing phase separated fuel repeatedly.. so again, lets not sound foolish.. My bottle is still going strong, clear, clear clear...and actually, here are the instructions on the bottle for your reference..As you see it's actually getting clearer,, because in the instructions it says it can take up to 4 hours to work..
you seem pissed it works as I said, I did it right here today, with this thread in the background for everyone to see.. I dont get why you think using the product correctly is wrong..If you were making iced tea, it said 1cup of powder to 1gal of water, you used a half a cup and a gallon of water, it it going to taste the same??? Get over yourself, you did it wrong, you claimed you did it as in the video and later it came out you really didn't do it as in the video..
Get use to seeing that bottle, you're going to see it all week crystal clear...
Just a heads up about the burn test, you said you're not planning on riding your sled on fire..another foolish/childish reply...FYI, your sled runs off what is in the fuel tank, The burn test shows how how little carbon is produced by MIB and how much carbon is produce by the other products while it is being burnt inside your motor..carbon build up is not good for your valves, pistons, exhaust,ect so you know..
Please leave me alone and don't bother me anymore and if you insist on this childish behavior then just P.M. me and I'll gladly give you my address and you can guess for what.
Bigdog, I'm not mad or anything, but you didnt use the correct product #1 Then you said you did the test exactly like the video, but later you admit you didn't #2. You said the instructions on the bottle say something they dont say #3.. I mean WTH.. You just make it up as you go..
And sorry, you dont control the internet, im sure there is an unfollow feature on here if you dont want to see my posts... still clear and zero separation..:)
