Mountaintech
YamahaFreak said:I like the idea of this skid, def looks like it will help from impact a bit
Thanks, if you are riding a Nytro with just the "protector plate" you are leaving yourself open to a world of hurt. Just ask the people who have found out the hard way. There are a lot of people out there doing just that.
marsh14
Has anyone installed one after installing the yamaha plate? I had to drill out the mounting holes to install the Yamaha one. Will this one still work?
Littlehoe
marsh14 said:Has anyone installed one after installing the yamaha plate? I had to drill out the mounting holes to install the Yamaha one. Will this one still work?
I will answer that... Yes.... I had the float plate on my nytro prior to getting the Roest plate so I had the holes drilled in my panels as well. I just used the same drilled holes with big washers. I put the Roest plate in the proper spot replacing the factory plastic plate and then just put the screws in through the panels then roest plate and tightened them down.
I will try to get a pic later today...
Mountaintech
Absolutely. The stock hole size was 8mm to capture the OEM plastic push type fastener. Installing rivnuts to fasten a plastic skidplate requires enlarging holes to 10mm. For installing a Roest skidplate that 10mm hole will work just fine, just get rid of the rivnut by sanding off the head. Roest instructions actually say to enlarge the hole to 3/8"(9.53mm) but 10mm is just as good because you're going to snap in a U nut.
Mountaintech
Littlehoe said:marsh14 said:Has anyone installed one after installing the yamaha plate? I had to drill out the mounting holes to install the Yamaha one. Will this one still work?
If I am understanding you correctly you have installed the skidplate incorrectly. The skid plate gets fastened independently of the side panels. No need for big washers. The Roest skid plate gets fastened, then the plastic panels slide into place and get fastened, just like OEM. No fasteners go through the holes that were drilled in the plastic panels to mount plastic skid plate.
marsh14
Do you have any ready to ship? I just ordered one.
Mountaintech
Sure do. It'll go out first thing Monday morning.
marsh14
Thanks. I just pulled off my skid plate and saw that it has been rubbing on my oil filter.
Mountaintech
marsh14 said:Thanks. I just pulled off my skid plate and saw that it has been rubbing on my oil filter.
Shipped. You should have it Thursday. You'll be good to go for the weekend!
yamahabandit
I've tried to order several times using paypal,not working ,don't know why. Will order one as soon as I can order over the phone. Like someone stated earlier on this post, really cheap insurance. Don't know why anyone wouldn't spend a few bucks to possibly save an engine.
marsh14
Great, Thanks.
enticeraised
Does your oil filter hang below the bottom of the engine sump pan?? I took mine off and its rubbing on the oil pan. The oil filter is at least another 1/2" higher than the pan bottom so unless massively deformed the skid plate would contact the oil pan first.
marsh14
Yes it does. I am running a napa gold filter which is longer than stock.
enticeraised
My stealership says there is three different lengths available
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
Just ordered mine today...IMHO the best snowmobile skidplate I have ever seen, more then worth the $$ for the peace of mind next winter.
- 8K
