04rxwarrior06
#2 carb from clutch side has been giving me alot of problems. when i bought the sled that plug was fowled changed plugs noticed fuel pouriung out the over flow from 1+2 carbs. found a small burr in the brass piece that the needel float valve rides in. i took fine grit sand paper got the burr out and stopped that problem. since then i cleaned the carbs 2 times took them all apart in a bucket then put them back together and fuel is now comming from the small hole on the inner part of the carb flange where the air box clamps to it next to the other small holes while it is running and when its off i notice drips comming off the float bowl. the needle looks fine, the brass pieve looks fine the float works i cant figure it out!!!!
dhkr123
Is the float height set right? If yes, might be time to actually REPLACE the valve set.
04rxwarrior06
yes i checked it everything looks and operates right. the valve set is number 8 i think on the parts diagram right comes with seat and needle?
dhkr123
I don't know what number it has on the parts diagram -- those numbers are only relevant for the particular picture you get... it might be 8 on that picture, but 14 on the next one.
Whatever actual PART NUMBER it lines up with, it comes with the seat, needle, and the wire catch that hangs on to the float.
04rxwarrior06
im going to take it apart tonight switch them and see if its that or something cracked or wrong with the carburator
04rxwarrior06
O rings where bad on the seat, its good to go now
dhkr123
You serious? The o-rings? Thats.... weird.
04rxwarrior06
yeah fuel was seeping right by the seat letting it flood that carb..... who would have known
