Secondary Spring Adjustment
200smk
Saskatchewan, Canada
Hey Guys,
I am moving my secondary setting from A1 to A2 to bring my rpms up a little after the Ulmer Clutch kit install.....just want to make sure I know what I'm doing!
I've read what seems like 2 ways of doing it:
1.) Remove circlip that holds helix in place. (Special tool required?)
2.) Remove the 3 philips head bolts on the back of the secondary...slowly releasing the spring tension.
Can you guys that have done this give me a few pointers?
Thanks!! ;)!
200smk
#1 snapring pliers is needed but in a pinch a small screwdriver could be used to get clip out.The spring is not under that much tension.This is something that you will find very easy to do once you do it.When in there check the buttons,clean off any grease and polish the helix.
