Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Now that this spring has been out for quite a few years
What wrap is everyone using now?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
6/3 with a 45 helix. 1.25 track, 270 tune, 200+ studs. Heavy Hitters 67 grams, 911 cover, XS 825 belt
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
3 and 1 with big venom kit.
Janne339
- Oct 31, 2015
- Sweden
- Sweden
- 2021 Sidewinder LTX GT
6/3 with a 45 helix
What secondary rollers are you running?
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Most off-trail sleds and high hpr sleds are running 3-1.
On trail sleds are 3-2
This is an average from all our customers
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
http://stmpowersports.com/2017-yamaha-sidewinder-driven-rollers-upgrade/What secondary rollers are you running?
These i really like.. They are a little different then the picture. They have steps on the outer edges
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Going to be ALOT of variables on this setting for a TP orange spring.. Helix angle , studs, track height, tune, etc.. So be careful trying to decide based on what people say..
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
This is true...
This is where clutch temp and performance feel are a must.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Thunder Products clutch kit
33/35 helix
1 1/4 track with 96 studs
No tune
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I updated mine also!Thunder Products clutch kit
33/35 helix
No tune
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Running all day today on the 300ss header tune.
Hh weights 63 gram base weight. Total 77.4 grams set up as follows.
3/4" in heel
7/16" steel bolt in middle
1/2" steel bolt with two thick washers in tip
Orange primary spring
Orange secondary spring at 3-2
35° helix
Hi torque rollers in secondary
58.00 mm offset setup up with hurricane 1 to 1 tool zero float.
XS825 belt
Edited to add,
Running nytro primary clutch with 911 cover.
Would pull super hard 90% of the time and once in a while could feel belt slip so I back off right away In the sugar lake effect snow trail riding.
fourload
I have run both 3/1 and 3/2 wrap. Both work great . Now that I am tuned I use 3/1 with a Dalton 35/39 helix and an XS825 belt. Runs great with great belt life.58 offset now but never blew a belt @ 61 either.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
33/35 helix
No tune
Broke down and bought a XS825 belt....lol
So 3-2 will work with it?
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Try it and see how belt temps are. If you are mainly trail...you will be good at 3-2
Terry
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
Terry
Thanks for the reply Terry
- 8K
- 6K
- 21K
- 30K
- 6K
