foolery
- Sep 12, 2015
- Cambridge
- 2016 Phazer.... plus a couple of 2016 Polaris 800's
have a ltx se 137" with 144 studs
Just changed flattened rollers to Cat substitute....
Blew original belt at 280 miles - it was broke in correctly
Stock spring setting on secondary is 3-3
From what I understand changing spring to 6-1 will give better belt grip and suggested when studded.
Is this correct?
Is this correct?
jpr-ltx-dx 2015
- Sep 21, 2014
- sr viper ltx dx
yes,correct.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Is there any first hand experience with this setup on an ltx ?
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Not saying the 6-1 is not better or worse.. Saying guys should also be checking clutch offset and secondary spring bind.. I had no shim behind secondaryhave a ltx se 137" with 144 studs
Is this correct?
The shim I refer to is on the jackshaft behind secondary. Used to align for clutch offset.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
That's disappointing that they forgot the shim.Not saying the 6-1 is not better or worse.. Saying guys should also be checking clutch offset and secondary spring bind.. I had no shim behind secondary
buyrite01
The secondary floats so shim won't do anything anyway.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
So why set offset? Why would it be in the book. I respectfully disagree buyriteThe secondary floats so shim won't do anything anyway.
up.mi.man
- Feb 23, 2009
- Marquette MI
- 2017 sidewinder ltx se
- Marquette Mi right on trail 417
i have 192 1.450 studs in my ltx se and it is set at 6-1 with no problems belt looks good after 400 miles.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
The shim is absolutely needed. You are correct. I've seen this happen before.So why set offset? Why would it be in the book. I respectfully disagree buyrite
- 17K
- 50K
