yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
yes in Yamaha's book
Thanks.I will look for that.What book?
yam177
- Aug 14, 2008
- Shoreview MN
Any of the technical update book. I got one from Yamaha
yam177
- Aug 14, 2008
- Shoreview MN
There might be a few copys of the pages on the 2 stroke side look there
2stroken
Is this the correct clutch that doesnt require the modifications?
looks correct but you need to measure the spline depth as that is the main difference. yamahas did the mod for his phaser if i remember correctly.
Do you know what it came off of.Is this the correct clutch that doesnt require the modifications?View attachment 177534View attachment 177535
The 95-96 fit.
2stroken
I purchased it from Ebay, it said 1996Do you know what it came off of.
The 95-96 fit.
2stroken
Details on measuring the spline depth?looks correct but you need to measure the spline depth as that is the main difference. yamahas did the mod for his phaser if i remember correctly.
this thread has the info needed to make sure the spline is the right legnth.
ty4stroke.com
The New Secondary Brain Child Is Done And Is Easy To Do
Well the stock Phazer secondary took a crap and I was not gone to be limited to fixing that pathedic vintage thing. So the brain child went to work on a fix with some adjustability options and found it pretty easy. My dealer gave me a new style secondary clutch to borrow from the 2010-11 models...
ty4stroke.com
2stroken
Thanks, I am hoping I can see the later model and the older model side by side inside the splines. Not visualizing it very well.this thread has the info needed to make sure the spline is the right legnth.
Well the stock Phazer secondary took a crap and I was not gone to be limited to fixing that pathedic vintage thing. So the brain child went to work on a fix with some adjustability options and found it pretty easy. My dealer gave me a new style secondary clutch to borrow from the 2010-11 models...ty4stroke.com
- 61K
