raptordan
- Jul 5, 2004
- Barrie ont.
- 2017 sidewinder ltx le
I did the exact same thing...even used checker plate also but put the checker side up It works great,less than half of the snow-ice build up than before.You will be glad you did it.
YamahaFreak
The Pen is Blue
Just riveting it to the tunnel protectors?
5/16 stainless button head bolts with lock tite
nytro addict
I just riveted mine to the top side of the tunnel protectors.
YamahaFreak
The Pen is Blue
Another project to add to the Summer list
only took about a hour. droped the rear of the suspention and you have a bunch of room. just another reason to go out in the garage and drink beer.[/b]
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I have a sheet of aluminum ordered and will be doing some sort of close off along the protectors but I have a tunnel heat exchanger to consider. I like the idea of a partial close off but would like to see some pictures of ice build up with this setup.
as soon as I can go riding I'll post results.
Rayman5271
- Oct 3, 2009
- Northern Maine
- 2016 Yamaha SR Viper XTX SE
I'm pretty positive your going to have issues here. I tried a piece of Royalex where you did... it worked great, until I bottomed out. Luckily I was using royalex and not steel or ^. I'm pretty sure when I hit it would have ripped the track off. I do have studs... but I did a bump check when I got back and it's going to be close up front even with a stock sled.
cawcislo
Anyone have a picture of the plate and dimensions. Are there any bends or just a straight piece of aluminum and some rivets/screws?
sprintcat
Ray man hows it going to be a problem if it is above the protectors?
that's what I thought above the protectors no problem. It is just a sheet of aluminum. can't remember the size. I will go out in garage tonight and get some numbers.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I purchased a .05" thick 2' X 3' sheet of aluminum that I plan to install on a RTX with a tunnel heat exchanger. I was hoping to see a few pictures of how well the semi closed and fully closed help prevent icing before I do the install. I think doing a full enclosure mounted to the bottom of the protectors would work the best but may be to restricting. The tunnel exchanger has worked well and I don't want to interfere with its ability to dissipate heat so I'm leaning more toward the semi enclosure because it is less restricting. Has anyone done a close off with the tunnel exchanger?
LazyBastard
If the purpose of this is to stop the ice buildup, would it be better to just remove the tunnel protectors? With nothing for the ice to stick to, it won't build up. Saves a bunch of weight too (instead of adding weight).
