Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
On 06 Apex RTX.
Top gear done and now need to set chain tension.
Turn till finger tight then lock in???
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
finger tight minus 1/4 turn. If you have reverse, you'll still feel slop when rotating the secondary.
Sidewinder
- Mar 19, 2005
- Ontario Canada
- Waterloo
Thanks bro , Now I can finish it up.
LET IT SNOW !!!!!!!!
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
I try to wiggle the secondary back and forth too, even though on the reverse sleds there is slop. That just helps center the tension on the chain, due to the track holding it on one place.
- 10K
