twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I replaced the stator in an 05 Vector last March with one from RMStator. I had read good reviews but I am second guessing that now. Because of the crappy winter, the sled has been ridden probably less than 40 miles since then and the replacement stator failed. What is interesting to me is how melted/burnt the 3 white wires are that were under the wire protection sleeve. Have you guys seen this before? Just a bad stator from RMStator?
It has been sent back to them for warranty but I am putting an OEM stator back in this sled. Regulator/Rectifier checks out fine.
Yogi_12
- Mar 4, 2012
- Stephenville, Newfoundland
- 2011 RsVenture
I'm by no means an expert on this....but I think I read on this site that sticky starter solenoid a can cause stator to burn up pretty quick. Might be worth looking into.....from my reading staters aren't chep....and a fair job to tackle.
Again, you can't take my word on this as gospel...but im sure I read it here. I seem to think Cannondale was involved on the thread conversation. Might be worth searching forum for it...might save you some future grief.
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
And neither am I but here's my .02 anyways. It's hot inside that engine cover! Too darn hot for electrical components or more specifically the insulation on the coil windings. Notice how one side of the unit is fairly burnt and the other is OK? That's a clue. All the coils share the electrical load equally so it's not possible for the coils on 1 side to suffer more than the coils on the other side due to excessive current draw.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Thanks. It is my boss' sled and he decided to go the cheap route with the stator from RMStator last year. It is getting a new OEM stator put back in it. I never want to do a stator job on one of these again... and I am not even pulling the motor. Pain in the #*$&@!
I just had never seen one melt the wires so bad on the outside. Lucky it didn't start a fire.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I've got a good used yamaha one with only 300 miles on it if you need one.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Thanks, but I already have the new OEM one.
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
i replaced mine last year with RMSTATOR and got a wopping 300 miles out of it, OEM stator lasted 8k, returned it and had travis ship me a used OEM and running fine for 2k since.
Dave hache
- Dec 27, 2019
- 2008 phazer 500
The pick up on aftermarket needs to be reversed where it plugs into plug have same issue just figured out
yank
- Jan 3, 2006
- Cook,MN
- 2005 rs venture
2006 rs rage
1971 elan
I got 1000 miles out of my RMstator. OEM is much better.
CharlieAZ
- Dec 20, 2016
- Nutrioso, AZ
- 2015 Yamaha SRViper LTX DX and 2005 Yamaha Vector RS ER makeover 2017/2018
- Vail,az
- AOL
- Palmercmp0466@aol.com
Greetings!
What is the best check to determine of Stator is gone? I put in new battery this year , and Got one Ride out of it , and then it would not turn over ...
I used Jumper , got it started ran for a while, it cut out , then would not turn over ... Sorry never dealt with this before... its a 2005 Vector only has about 3k miles on it ... Ran great last year put about 400 miles on Sled .. also getting some backfiring now as well, Wondering if it could be related as I know Sled wont run well if battery is low ... Thoughts ?
Also, should mention Stator has never been replaced before since I owned Sled(Orginal Owner)
Charlie
Charlie
best test is to check on the boost leads and see if it is charging at 2000 rpm. you should see over 13.5v if it is charging. make sure you check the wiring at the voltage regulator in the nose of the sled as they have been known to corrode and loose contact.
Banjo Man
- Nov 5, 2012
- Lake Barrington Il.
- 06 Vector GT. 15 Vector Ltx . 14 Vector Ltx
Greetings!
Charlie
I had an 06 Vector GT and it started to backfire. Was definitely the stator.
