IBABAD1
I don't know if this was posted about how much boost the Sidewinder has,I thought I would share with everybody what I was told Sunday at the 2017 show at Yamaha Factory in Wisconsin 4/10/16. There is no Boost gauge. The Sidewinder puts out 13 pounds of Boost. Will maintain boost at most elevation up to 13 pounds of boost. Just FYI. Had a great time at the show with all the TY members. Mr. Sled did a great job. Thanks.
kviper
Are you sure it maintains 13lb at all times or up to 13 to maintain power at higher elevation?
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I read somewhere the ecu reads the amount of octane your using than adjust boost on its own. That's what I translated. So higher octane higher boost? Please correct me if I am wrong
IBABAD1
Yes that is what the factory rep told us.Are you sure it maintains 13lb at all times or up to 13 to maintain power at higher elevation?
swampcat
Read SOMEWHERE it was tested up to 30 lbs.
yamalou
- Feb 3, 2009
- Mundelein IL
- 2017 SIDEWINDER 141 XTX SE, 07 ATTAK, 07 PHAZER
Wow, sounds fun and dangerous, how do I get that job???
IBABAD1
You are correct, up to 13 at higher elevation.Yes that is what the factory rep told us.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Seems like a lot of boost from a little turbo, I would think it would turn into hot air pump well before 30 psiRead SOMEWHERE it was tested up to 30 lbs.
kviper
I did some checking because this wasn't adding up. It does not monitor octane, It monitors knock and lowers boost and pulls timing to safe guard! If you put lower octane in and knock occurs it will make the adjustments and you will loose power.
Boost range is from 9 to 13lb. It will increase boost UP TO 13lb as you increase elevation to maintain power. It was said that the sled at Dynotech was around 9lb.
Stigapex
Suspended
30 psi is way to high for that turbo. It's made to deliver at its best up to max 20 psi. Over that its ineffective.
13 psi boost , and only 180 hp.
Yamaha have made a very safe setup. Its only +70 hp from the engine without boost. Normally its no problem making 10hp pr psi. =+130 hp
bleedyamaha
- Sep 28, 2013
- Northern Iowa
. So octane triggers the knocking so we really want to run 91 octane so we don't loose,power. Now we need to trick the ecu into thinking we are at high elevation for us flat landers. Probably a flash out there already waiting for us!I did some checking because this wasn't adding up. It does not monitor octane, It monitors knock and lowers boost and pulls timing to safe guard! If you put lower octane in and knock occurs it will make the adjustments and you will loose power.
SRX Boy
That motor should generate more than 70hp without turbo. Need to look at the rated hp of the YXZ side by side...
Sent via Tapatalk
Sent via Tapatalk
Interesting. Do you know that the guage has a calibration mode for altitude? At least on Vipers. At the show last weekend a few Winders we looked at were showing 9000 ft. Would have to check wiring since there is more than one map/baro/boost sensor.. So octane triggers the knocking so we really want to run 91 octane so we don't loose,power. Now we need to trick the ecu into thinking we are at high elevation for us flat landers. Probably a flash out there already waiting for us!
Sent via Tapatalk
I believe they are 120hp. Sidewinder is lower compression and different cams though. Probably 100-110hp. Who said 70 without turbo?
Knock light is first mod I would do to Sidewinder. Wish I would have played with guage more. Phazer has the knock light right in guage. Very possible it's in sidewinder also.
- 7K
- 48K
