Sidewinder clutch bushings ( life expectations???)
Blackapexse
Lockport ny
Apex se
I'm having my track swapped on my 2017 sidewinder with 9500 Miles. I replaced the primary clutch rollers but I was wondering how long do the brass press in bushings last in primary and secondary clutches??? Should these be replaced?? Also many miles would you trust the drive chain in the chain case to last?? At almost 10k does that need to be replaced or just inspect and reuse. Just trying to prevent any failure points while track swap is being done.
never hurts to change that kind of stuff if you dont know the history of the sled.
Change the chain, check the top gear bushing in the chaincase. Check the bearings on the jackshaft & driveshaft and check the bushings in the clutches.
