CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Wow!
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
I wonder if it adjusts boost to compensate for elevation. Maintaining the same hp at all elevations like MCX does. I am thinking no since the btx has different clutching for flat land.
4sStrokeNoSmoke
- Sep 18, 2014
- ND
- XF7000 "2014" MCX 270 kit
I think this ECU is going to be a big player in the aftermarket segment
No O2 sensor?
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Literature states same hp at any elevation, so the answer is yesI wonder if it adjusts boost to compensate for elevation. Maintaining the same hp at all elevations like MCX does. I am thinking no since the btx has different clutching for flat land.
- Apr 14, 2003
- Hessel, Michigan
No O2 sensor?
Nope, no 02 sensor.....
Pretty much same ECU as the Nytro with the extras for the turbo monitoring. Best thing they ever did was get rid of that Cat ECU.
As I said all along, they should have just kept the Nytro ECU in the Viper, figure out the gauge pod and handlebar controls. 95% of the issues with the Viper could have been avoided.
Tarzan
- Oct 28, 2009
- Norway
- www.youtube.com
- Norway
I hope the rev limiter is raised on this engine. Hitting the rev limiter at 9150 with turbo is not so nice for the engine. So i hope the rev limiter is higher now, At least 9500 rpm .
The Nytro was set at 9250 rpm
And Viper at 9150 rpm that is to low.
I now the clutches isnt suposed to go over 9000 rpm but, there are snow conditions that can be so you hit the rev limiter at 9150 rpm and then the valve cap can come loose.
Ill post again here too.. its 9500 rpm.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Is it cat harness with same goofy throttle lever?
Yep
yamahaex50
- Jan 6, 2005
- Pittsburgh, PA
- Sidewinder LTX-LE
Nice that it will compensate if you get in a bind and can't find 91 octane gas.
possessed
- Apr 18, 2003
- Sidney ME
- 2017 Sidewinder LE RTX 129 Curve Skis 1.0 track header tune 280 hp
08 Apex LTX Yamachager
1998 SRX Bender 835
03RX1/ 1993 Thunder Cat
- YAHOO
- rx11000@yahoo.com
Yah that's a great idea !!!!! The technology is really something!!!!!!
sheetwright
- Jul 7, 2008
- Northwoods USA
- 2021 Yamaha SRX
The question is, can you get your hands on a extra ecu. That way you can have that one reflashed, and then keep the stock one on the side. I know some cat guys do this to make sure their warranties don't get voided. Being the manufacturer can read if you screwed with ecu, of something went wrong.
I think that will be really expensive option... but a great idea.
