DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Purchased a 35/39 Dalton today, on sale too!! Can't wait to try it out!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Installed straight 38 from STM.. Also Ulmer rollers. I had cat rollers and think they are fine BUT the STM helix appears to have slightly more narrow ramps(or sharper edges).. The Ulmer rollers have a beveled outer edge to them and I like that better.. I had to grind out the spring hole on the helix for the spring TANG(I think I am saying that right?? ).. This allowed the spring to sit in hole/pocket.(better) The stocker helix has these bevels on the spring holes. I wound the spring to 6/1 and tightened everything.. The rollers all were 1/16-1/8 off the helix ramps. ?? Kind of thought "what the hell".. So I installed on sled and tightened down and while doing so(which sets belt deflection) you can watch the rollers tighten right down onto the ramps.. Not sure this means much BUT if you have aftermarket secondary adjuster you might want to try tightening(knob) it down some and watch the rollers while doing so. I took mine(secondary adjuster) off and run the stock set up with washers. I know you loose some of your belt height(deflection) on top of secondary but on mine it helped to bring the rollers right down onto the helix. I DID NOTICE this some with stock helix also(after ditching secondary adjuster and going with washers)). this is with 8jp belt and secondary set at 6/1. And maybe it will not help with other guys based on the variations on these secondary's, BUT it made a big difference on mine. with both helixes(stock helix>6/1 and STM helix>6/1).. So maybe try loosening your belt deflection(tightening knob - if you have a aftermarket secondary adjuster) SOME and check rollers after.. easy enough to try. Or switching washers on stock set up
twiz28
- Nov 8, 2004
- New Brunswick, CAN
- 2017 Sidewinder BTX 1.75 Backcountry
2017 Sidewinder XTX 137
Let me know how you like the Dalton, thinking of trying this. I'm on the East coast but do some contract work in Espanola, maybe I will touch base with you when I'm up there, see first hand your results.Purchased a 35/39 Dalton today, on sale too!! Can't wait to try it out!
- Apr 14, 2003
- Hessel, Michigan
Installed straight 38 from STM.. Also Ulmer rollers. I had cat rollers and think they are fine BUT the STM helix appears to have slightly more narrow ramps(or sharper edges).. The Ulmer rollers have a beveled outer edge to them and I like that better.. I had to grind out the spring hole on the helix for the spring TANG(I think I am saying that right?? ).. This allowed the spring to sit in hole/pocket.(better) The stocker helix has these bevels on the spring holes. I wound the spring to 6/1 and tightened everything.. The rollers all were 1/16 off the helix ramps. ?? Kind of thought "what the hell".. So I installed on sled and tightened down and while doing so(which sets belt deflection) you can watch the rollers tighten right down onto the ramps.. Not sure this means much BUT if you have aftermarket secondary adjuster you might want to try tightening(knob) it down some and watch the rollers while doing so. I took mine(secondary adjuster) off and run the stock set up with washers. I know you loose some of your belt height(deflection) on top of secondary but on mine it helped to bring the rollers right down onto the helix. I DID NOTICE this some with stock helix also(after ditching secondary adjuster and going with washers)). this is with 8jp belt and secondary set at 6/1. And maybe it will not help with other guys based on the variations on these secondary's, BUT it made a big difference on mine. with both helixes(stock helix>6/1 and STM helix>6/1).. So maybe try loosening your belt deflection(tightening knob - if you have a aftermarket secondary adjuster) some and check rollers after.. easy enough to try. Or switching washers on stock set up
You can add or take away washers for belt deflection also on the stock setup
DMCTurbo
- Nov 12, 2005
Domtar I bet, by all means get in touch with me...Let me know how you like the Dalton, thinking of trying this. I'm on the East coast but do some contract work in Espanola, maybe I will touch base with you when I'm up there, see first hand your results.
Keith Schmitz
- Jan 12, 2015
- Dousman Wi
- APEX
I just got my 35/39 in the mail today! Excellent, fast shipping! Ordered Tuesday, would've gotten it yesterday, but I missed the FedEx guy. I'm pretty excited to try it.Purchased a 35/39 Dalton today, on sale too!! Can't wait to try it out!
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Where did you buy it?I just got my 35/39 in the mail today! Excellent, fast shipping! Ordered Tuesday, would've gotten it yesterday, but I missed the FedEx guy. I'm pretty excited to try it.
DMCTurbo
- Nov 12, 2005
drivepower.ca is where I purchased mine, dealer for Dalton, on sale as we speak.
Keith Schmitz
- Jan 12, 2015
- Dousman Wi
- APEX
Yup! That's where I got mine!!drivepower.ca is where I purchased mine, dealer for Dalton, on sale as we speak.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Well what is the verdict?Purchased a 35/39 Dalton today, on sale too!! Can't wait to try it out!
twiz28
- Nov 8, 2004
Yeah I'm waiting to hear too!!!!!
DMCTurbo
- Nov 12, 2005
Haven't received it yetWell what is the verdict?![]()
twiz28
- Nov 8, 2004
I'm just like a kid at Christmas time! Can't wait to see whats in the box!
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Who in the USA carries them?
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
I know I got a Dalton helix from Ulmer Racing in the past. Not sure what he stocks but give him a call.
