FleuryPerformance
- Feb 23, 2019
- Alma
- 2018 Yamaha Sidewinder MTX LE 50th
I only wanted to share my CCV reroute system for my Sidewinder MTX.
Since we cannot remove the roll over valve and do a loop to make the oil vapor escape, i’ve built this venturi into the exhaust setup.
No more oil in my turbo, intercooler & piping !!
I still can flip the sled over and over without any oil drip.
Hope it help.
blown apex
- Jan 29, 2006
- ALTON ILL.
- ristermotorsports.com
ok ?? hows that going to work
muffler has backpressure
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
I’m thinking it won’t unless the roll over valve acts as a one way check valve
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Which won’t open under pressure from exhaust pressure
FleuryPerformance
- Feb 23, 2019
- Alma
Here is how is made in the inside.
It’s called the venturi effect, it made a lot of succion from the exhaust flow.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Have you run it ? Now that you show the internal pipe it should work
You might have to Turn the internal pipe so the high side is hit with the exhaust first to create more negative pressure
FleuryPerformance
- Feb 23, 2019
- Alma
Exactly, that’s what i did and it work perfectly. Very happy with this.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
I like the concept. Are you building those for resale.
I’m not trying to be disrespectful but I would be concerned about maybe to much suction and maybe pulling oil out. Or have you run it enough to rule that out. Maybe that’s not a valid concern
Would a smaller Venturi pull less I wouldn’t think it requires much at all
Neat idea though
Neat idea though
FleuryPerformance
- Feb 23, 2019
- Alma
Thanks for your input, honestly I don’t think I will build and sell them, but I can give you the infos if you wan’t to try your own.
I drilled the bung plug with 1/2´´ bit. I’ve welded a 304 SS tube of the same diameter. I have slighly bend the tube and made the cut on the picture above.
I have plugged all the OEM intake vacuum ports.
I have taken an old hose and cutted it to the correct lenght and plugged everything you see on the first picture (with the roll over valve).
If you have any question, feel free to ask.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
Thanks I can handle the build. And you haven’t noticed any oil consumptionThanks for your input, honestly I don’t think I will build and sell them, but I can give you the infos if you wan’t to try your own.
That would be my only concern. Kinda brilliant actually
FleuryPerformance
- Feb 23, 2019
- Alma
Actually I did not notice anything, i’ll give you news if there is something wrong with this.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Has anyone else tried this?
Is this the kit you used?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
this also looks like an option
FleuryPerformance
- Feb 23, 2019
- Alma
That’s an option I was looking for but never tried. Should work no problem IMO
- 9K
- 8K
- 173K
