walter
- Nov 22, 2014
- Linwood, MN
- 2015 Viper LTX LE Turbo
2009 Nytro XTX
2002 SRX 700
Do we have any HP numbers?
They have not given actual Dyno number but have put it into the 180HP range. I am hearing its above that from sources... but until we get a production model and get it dynoed its only speculation.
walter
- Nov 22, 2014
- Linwood, MN
2009 Nytro XTX
2002 SRX 700
That is what I was figuring being that most 800 two cycles are within the 180-185 hp range.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Take 30 HP off those 800 figures and you'd be spot on!
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
800 2STROKES are not 180-185
walter
- Nov 22, 2014
- Linwood, MN
2009 Nytro XTX
2002 SRX 700
Well what is it then? I think my buddy with a cat 800 had like 160horse or something stock..
They wish !
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
It's 160 stock then. Sidewinder is 180 stock.
Cat turbo is 185 I assume this motor is its replacement so right around there.
walter
- Nov 22, 2014
- Linwood, MN
2009 Nytro XTX
2002 SRX 700
Maybe I meant 160 then, haha idk guys give me a break
shadow44
Cat says 180 hp in their engine vid.
Here is some info on the Tunnel Coolers:
New Oil Tank
New Oil Tank
From AmSnow:
The new 3-cylinder Genesis Turbo should pump out around 195+ ponies according to Yamaha, who stated its goal was the first 200-hp production sled. Although Yamaha dynos say they might be short of the 200-hp mark, the new Sidewinder sleds claim the highest power-to-weight ratio in the industry, as much as 30% higher than the next closest 800cc competitor (Polaris Pro-RMK 800).
http://amsnow.com/news/snowmobile-news/2016/03/2017-yamaha-snowmobiles-released
The SideWinder has a built in roll over valve so you can turn the thing upside down and have zero issues. I will try and get you a picture later.
Here is a picture of the roll over valve system that allows the sled to be on its hood without puking oil.
