@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
is there someone tried the thunder product primary rollers yet? are they better?
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
I had a roller that wouldn't turn. The bushing inside the roller was not pressed in all the way. Put roller in vice....pressed it flush and issue fixed!!!
It will come out again. Keep an eye on it. Only a matter of time
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
If you go to the parts finder you'll see a lot of updated parts marked in red
- Apr 14, 2003
- Hessel, Michigan
@shagman, myself and a bunch of others are running Thunder Products rollers. Have been for awhile cause we knew found out way early that the stock rollers were not holding up. Not one issue with Thunder Products rollers and they are still like new.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Yep better. I’m running on viper 6000 or so miles and sidewinder 700-800 miles. All good so far. I’m running the 14.8mm ones in both sleds.is there someone tried the thunder product primary rollers yet? are they better?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Do you take a little more weight with the slightly larger size?
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
usually the larger the roller raise rpm so will need more weight but only 0.3 so if needed its not muchDo you take a little more weight with the slightly larger size?
shagman
Vendor
- Feb 18, 2014
No. Rpm change is very little. It’s usually not needed.Do you take a little more weight with the slightly larger size?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Same here. Easy fix.I had a roller that wouldn't turn. The bushing inside the roller was not pressed in all the way. Put roller in vice....pressed it flush and issue fixed!!!
Yamarus
- Oct 4, 2021
- Russia
- Russia
- Yamaha Sidewinder B-TX LE 153
I drove 2,400 km. Today I started to carry out maintenance. I removed one of the primary rollers and saw that the sleeve was worn out. I want to install all the primary clutch rollers from turbo dynamics at 14.8 mm. Do I need to change something in the settings?
Sidewinder B-TX LE 153 2020 model year.
Fleecer
- Jun 13, 2014
- 2019 SRX
No, just install.I drove 2,400 km. Today I started to carry out maintenance. I removed one of the primary rollers and saw that the sleeve was worn out. I want to install all the primary clutch rollers from turbo dynamics at 14.8 mm. Do I need to change something in the settings?
View attachment 167705View attachment 167706
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Just keep buying rollers....
Or switch to a apex, vector or nytro primary.
Ton of info on here about these rollers.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
OR buy a better roller? G force
If your roller has worn right through the bushing, be sure the pin surface isn't damaged.
I'm finding most Winders stock, and up to 250HP can get close to 5-6000 miles on the original rollers.
I've switched to the GForce, I like that they are wider with the nylon washer from the former Yamaha clutch. They also cost less than the Yamaha roller.
I haven't accumulated enough miles yet on the Gforce to see if they last longer.
I'm scratching my head as to why Yamaha would make room for a wider roller, but instead completely waste it with a wide washer(there was nothing wrong with the thinner washers).
If Yamaha made the same roller, but wider they would for sure last longer IMO.
Yamarus
- Oct 4, 2021
- Russia
- Russia
I checked all the fonts, they are fine, I didn't notice any damage.If your roller has worn right through the bushing, be sure the pin surface isn't damaged.
There is also wear on other bushings, but less.
Maybe add some grease to the bushings? Do need to lubricate the variator at all? Or only purging with compressed air?
