DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Pickle protector is only for the chaincase side, correct? I would like something for each side to cover both the chaincase and the brake rotor cover. If you can come up with something that looks nice Travis, I'm in. Every alternative out there right now is expensive so I would think you could make some money on these!
Unless Travis can come up with something Racewerx is the only option out there currently.
Im all for another BOP product!
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
When on Racewerx web page what Cat chassis should I be looking at?>
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I don't really like idea of adding wings to my main plate. There is no structure to keep an aluminum plate from deforming upon impact. If we rivet aluminum wings on to plastic an impact will bend plate and likely pull rivets out of plastic.
What I am thinking is something similar too racerwerx and pickle protector, but with smoother more gradual approach so objects glide over. While pickle and racewerx are robost pieces, they have rather abrubt edges a good snag point. As cannondale mentioned, we need glide action!
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Ill be first in line for some of those!
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
I'll be second!!!!
Make them big and thick enough so they dont deform. Incorporate exhaust pipe protection in right one. Titanium would be nice! Can you get that?I don't really like idea of adding wings to my main plate. There is no structure to keep an aluminum plate from deforming upon impact. If we rivet aluminum wings on to plastic an impact will bend plate and likely pull rivets out of plastic.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Got my skid plate from BOP looks great. One more thing off my list. Thanks Travis
AXR
- May 5, 2007
- Central NY
- Current: 2017 SideWinder L-TX LE
Past: 2015 Sr Viper R-TX SE, 2008 Apex RTX, 2002 Sx Viper, 1997 XTC 600, 1991 Doo Formula Plus.
Alright. My dealer got in a Viper rear plate and it will work on the winders with a little modification. They have not performed it yet. I had to ok it tonight before they went ahead and started cutting a $150 skidplate. From what they could tell holding it up, all that will need to be done is to cut the 2 front tabs off and to widen the exhaust hole a little bit. Possibly new/widening of the screw holes in the plate as well. Once complete and I finally pick the sled up I will try to post a cpl pix and let you know how it turns out. My best guess would be next week, as they have to order a 2nd one for my Dad's sled. Here is a pic showing the ares in red that will need to be modified.
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Please keep us informed
Right on AXR!
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
This would be great!
Do these have to be removed to access the oil filter?
Yes unless modded. Awesome mod tutorial in Viper FAQ.This would be great!
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Has anyone noticed that the bottom of the winder is flat? The brake disk and chain case doesn't hang down any more. Haven't looked close enough to see how they pulled that off.
Kevin
- Dec 20, 2006
- Ottawa Canada
- Sidewinder
I'm pretty sure I have bumps for both in the stock pan
But never actually looked to see if they hang down
