Firedawg1998
- Oct 17, 2018
- Sudbury, Ontario
- 2019 srx
Hurricane PM bundle
2012 apex xtx
2012 vector gt
Ya, I couldn't be more happy. Mileaged my apex upto 20,000km and switched to the srx for the comfort upgrade so now I rode even harder. But tuned and running a 22t has helped. Now my 900t friends all share roughly the same range as i
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Best end of last year was 15.6 mpg, average farmland trail riding, filled to the cap both times. Better than the apexs, including my 06.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Good numbers...i think there's a good amount of guys in the 12-13mpg range. Blame 90% of that on flipper control. who wants to buy a race sled and ride slow?!?! Probably just me & you. Haha...Best end of last year was 15.6 mpg, average farmland trail riding, filled to the cap both times. Better than the apexs, including my 06.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Yeah, its not flat out for sure, but some nice speeds in the bigger fields.Good numbers...i think there's a good amount of guys in the 12-13mpg range. Blame 90% of that on flipper control. who wants to buy a race sled and ride slow?!?! Probably just me & you. Haha...
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yeah it all matters when it comes to mpg. Gearing, clutching, track lug height, amount of fluff or sticky snow in trail, etc!
With a 4 stroke, I’ve found that low rpms at cruising speeds gives best results!
So what is a good rpm for your cruising speed, and what do you consider a good cruising speed. Gotta love how much speed one can get with little throttle on one of these!!
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Nice to know how far one can go, under normal conditions, especially when that wrong turn and no gas stations happen!
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
I did get 200km/tank, but now i am closer to 160km, all seemed to happen after i took it to the dealer for some stub shaft warranty work. I am about to pull off the valve cover to make sure i didnt spit any shims and that my timing lines up, after that i am not sure what to do, probably the closed loop. I have my suspicions that one tooth is jumped on the cam gear but wont know until i open it up
Doc Harley
- Oct 17, 2016
- Here & there
I thought I read somewhere in regards to closed loop & fuel consumption inconsistency's.I did get 200km/tank, but now i am closer to 160km, all seemed to happen after i took it to the dealer for some stub shaft warranty work. I am about to pull off the valve cover to make sure i didnt spit any shims and that my timing lines up, after that i am not sure what to do, probably the closed loop. I have my suspicions that one tooth is jumped on the cam gear but wont know until i open it up
It's just nice to know exactly what happened & why it happened, so you can move on. Ugh.....
Maybe put a call in to manufacturer and see what they say?!?!
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
If it was to spit a shim you'd know it. It would run like a twin cylinder.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The biggest difference that I have seen on fuel mileage is trail cruising rpm's for your normal speed that a person rides. Clutch setups make a difference here. Say like 7000 rpm vrs 6300 rpm's.
KnappAttack
- Feb 19, 2004
- Welch MN
Correct, it's why the bigger the tune, the better the mileage. Big tunes carry big clutch weight for the power, hence better mileage by keeping RPM lower at cruising speed. As a bonus the added power when you mash the throttle!
earthling
As well as being able to leverage a better gear ratio which also keeps RPM lower. If someone is running 24/50 I would expect RPM to be nominally higher always.
Doc Harley
- Oct 17, 2016
- Here & there
Which tune do you think would provide the best fuel consumption? Or are you saying all of them, in general?Correct, it's why the bigger the tune, the better the mileage. Big tunes carry big clutch weight for the power, hence better mileage by keeping RPM lower at cruising speed. As a bonus the added power when you mash the throttle!
KnappAttack
- Feb 19, 2004
- Welch MN
More power requires more drive clutch weight, so the bigger the tune, the more fuel mileage potential.
Doc Harley
- Oct 17, 2016
- Here & there
I didn't know....tyMore power requires more drive clutch weight, so the bigger the tune, the more fuel mileage potential.
