Rx1 cowboy
Im going to be dropping my skid down this week to install my hauck pipe. In the past ive always accessed the clamps under the gas tank but the apex/attak appears to be different than the rx series. I only want to lower than back half to make the connections, what is there to look out for with the monoshock and how hard of a job is it?
Rx1 cowboy
no one? i looked at the sled and it looks to me like i could take out the rear bolts and disconnect the coupling arm and the skid would drop is this all? also will the track need to be loosened?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I just took the rear 2 bolts out when I swapped an exhaust earlier. I have done this also without removing the skid at all, but it's a pain and you will have to wrestle it around if you don't drop at least the rear of the skid. The clamps are underneath the gas tank just like the RX-1 was.
dirkdiggler
Suspended
If you deside to Pull the skid completely make sure you set your Adjuster to full Hard before you remove the skid. It take 10 minutes to pull the skid. If it helps with teh install I'd recommend doing it.
- 149K
