Mattcull
- Aug 27, 2020
- New liskeard
- 2009 Yamaha venture lite
I have a 2009 venture lite. I’m looking to remove the skis to check bearings, install
Slider and limiter straps. Does anyone have info on how to take the skid out? I’ve never done it!
And a separate question, anyone have a link for a front skid plate or snow deflector so I can better floatation
Thanks for the help guys!
Remove the blocks that hold the spring tension on both side with the rear hung in the air about 2 inches off the ground and pull out all 4 bolts.
yamaha used to offer the skinz float plate for the phazer. i would think with some work it would work on a lite or mp.
as to the rear suspension removal, put rear of sled on stand or use a lift if you have one. loosen track adjusters all the way off. then un hook torsion springs from where they sit on the slide rail. pull the rear shaft bolts and compress the shock so that the rear scizors sit on the rail. might need to hold it down with a tie wrap if your shock still has a good nitrogen charge. then pull the front shaft bolts. might have to collapse the front arm a bit to get it out but now the skid should come out.
dang it lol. great minds and all.
Mattcull
- Aug 27, 2020
- New liskeard
I got the skid out!dang it lol. great minds and all.
Put on 8” sly dog powder hound skis
Greased everything on the skid
And looking to replace idler wheels
