09phazermichagan
mine does this to i am getting upbushman's kit. I already have it all apart it looks like every bushing and bearing in this thing is sloppy this is a 09 with 1600mi. LOL found this while useing google to spell check http://www.urbandictionary.com/define.php?term=slopp
Devin yamaha man
- Jun 8, 2014
- 2007 Phazer fx
136"
MBRP exhaust
Yamaha GYTR front shocks
My 07 phazer has about a half of inch of play i never notice it while riding....can the play in the steering get worse though?
gary.sooley
- Oct 22, 2014
- www.facebook.com
- 2010 phazer
I need help getting the old plastic steering bushings off my Phazer, tried to remove rod but the adjustment needs to be taken off. Tried to turn the lock nut on the rod but it needed to much torque so that's why I'm here before I break something.
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
I don't remember which but one of the lock nuts on each tierod is left hand thread.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Go to your dealer look at a brand new Phazer with zero miles on it and its got alot of play in the handlebars, its just the way it is. The bottom line is you don't notice it when out riding and having fun. Our last Phazers had 5000 miles of boondocking and some trail riding and the steering was never a issue. Never added a kit or changed anything in the steering.
Snowmixer
- Oct 29, 2010
- Snohomish, Washington
- 2007 Phazer Mountain Lite
2008 Phazer MTX
2012 Arctic Cat M800 153
Hello Gary, and welcome to the forum!
Looking at the first of the pictures you posted, I can tell you that the lock/jam nut shown has left-hand threads. So if you put a wrench on it while standing where you were when the picture was taken, you'll want to lift up and rotate the wrench towards the front of the sled. I apologize if you already knew this, but thought I'd mention it anyway. If possible, I would also suggest using a "flare nut" wrench to minimize the chance of rounding off the nut.
Good luck, and hopefully this helps!
gary.sooley
- Oct 22, 2014
- www.facebook.com
- 2010 phazer
I got the plastic washer off and am trying to order the brass bushings, thanks.
gary.sooley
- Oct 22, 2014
- www.facebook.com
- 2010 phazer
I got it figured out, just having a hard time contacting up bushman, as I last resort I will replace with crappy yam parts.
- 114K
- 6K
