jeffgilbert
- Dec 17, 2007
- Newfoundland
- 2019 Sidewinder BTX LE
I have installed Ulmers header and a osp exhaust i have some new mapping and i noticed a small pop / backfire when I come off the throttle. I basically have ulmers performance pack #6 with a different muffler. Has anyone noticed this before? Could it be from having such a short header and open exhaust?
Thnaks
Jeff
Thnaks
Jeff
- Apr 14, 2003
- Hessel, Michigan
Its because of the more free exhaust and the 2015 ECU.....you have the lean pop issue.
I take it you have a fuel controller, PCV? If you do, the area outlined in black is the area you want to change. **Now, this is just a sample map** If you are a -10 for example, change that to a 0 or +5....this will help your idle and part throttle.
jeffgilbert
- Dec 17, 2007
- Newfoundland
That's exactly what my map has going on i have some -10 and -5 in this area . What kinda mods are you running for this map I am also using and PC ignition module.
Thanks for the help
Jeff
Thanks for the help
Jeff
jeffgilbert
- Dec 17, 2007
- Newfoundland
Do you think this lean pop will cause any issues?
Jeff
Jeff
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
I had the same thing going on with mine, and NOS-PRO helped me out last weekend. I had all zero's in that same area and I switched them to +5 and my idle and startup is much better now.
jeffgilbert
- Dec 17, 2007
- Newfoundland
- Apr 14, 2003
- Hessel, Michigan
Thanks for the help
Jeff
I have the EVO header, muffler, airbox mod with EVO stage 4 flash.
Your welcome bud!
- Apr 14, 2003
- Hessel, Michigan
I have a lot of -10 in this area I may try putting in zeros up to 3250rpm should I change anything in the second column?
If it were my sled, I would have the 0 and 2% throttle columns at +5....down to 3,750 rpms and all 0's in the 5% down to the same 3,750 rpm. This should clean a lot of the burble and poor idling.
I have Excell Air box Mod, Straightline Header, Excell exhaust and the EVO Flash #4, I get a little on and off throttle burble, almost like a back fire here and there as well. I am sure its in the tune or maybe the short header does it...either way I cant really do anything about since the Evo Flash is non adjustable.
When you say "down to" you are referring to table columns top to bottom and not RPMs correct?
- Apr 14, 2003
- Hessel, Michigan
Yes, top to bottom starting from the left top corner.
I would call this 2 columns
I think jeffgilbert should change column 0,2,5 of the % throttle and from 500 to 3,750 rpm to the numbers I gave him.
jeffgilbert
- Dec 17, 2007
- Newfoundland
Thanks alot NOS-PRO I will make these adjustments the weekend and let everyone know what turns out likeView attachment 114748
- Apr 14, 2003
- Hessel, Michigan
You betcha bud
jeffgilbert
- Dec 17, 2007
- Newfoundland
Do you think this may help with some of my hot start issues I always found that I had to give it a little throttle to get it started when it was hot or sometimes when it would start it was hang really low like 950 and would be rough until I gave it a little tap on the gas?
- Apr 14, 2003
- Hessel, Michigan
Yes, this should help with that. The problem is not enough fuel and giving it throttle helped start it.
