Dano
found new tracks coming for 06. Here are a few pics....
The Hacksaw track will be available in the standard 15x121 and is simular to the ripsaw, but in a 1" profile....
..theTomahawk track looks trick at only 32 lbs
Dan
Dan
hmmm, I wounder how some of those will hold up.
tmk50
I wonder if the Maverick is the Apex Mtn track?
Auskins
the apex mtn got the variable height 3.0 pitch
i know its from camoplast but i don't think its this one
98srx6
- Feb 2, 2004
Maybe somebody could help me with the whole "Tomahawk comes with two half and two full sprockets?" thing.
Also, that shotgun track doesnt look clipped at all.
rx-1 blue reverse
impalapower
rx-1 blue reverse said:The Tomahawk is a 120" track. you need to change the sprokets to make the track fit. The attached file is a pdf file that Kimpex sent me after the Novi Snowmobile Show.
You're absolutely right. A friend of mine put one on his RX. The sprokets were tough to press on and then they weren't aligned after riding it, so they had to be moved. Once it was done, the track was really tight, it didn't stetch very fast. He loved the hookup.
Dano
Hmmmm...I guess there is a misprint on my Tomahawk add. Doesn’t seem to make sense selling a track 1" shorter.
I wonder how the shotgun track would work having all the windows closed off and clipped every second bar. Doesn’t seem to make sense not having snow lube the sliders...
Dan
Dan
Indy
Where did you find this info? I want to see more about the tri keel ski.
Dano
Indy said:Where did you find this info? I want to see more about the tri keel ski.
I just received my new summer Royal Distributing catalogue (simular to the Dennis kirk in the US) and it showed a couple sales and new items to come for the next winter season. Their web site is not updated yet so I took pics and posted....
Dan
pro116
120x3pitch that's good for the high horpower sleds that want a light track and limited ratcheting.
impalapower
pro116 said:120x3pitch that's good for the high horpower sleds that want a light track and limited ratcheting.
Mike has never ratcheted this track. But why did they make it 120"?
RTX Meirda
I have my eye on those skis!!!
Cheap too!
Cheap too!
tmk50
impalapower said:pro116 said:120x3pitch that's good for the high horpower sleds that want a light track and limited ratcheting.
The 120 length has to do with the pitch (2.52 vs 3")
a 3" pitch track has to divide evenly into it's circumfrence (120" / 3" pitch = 40
a 2.52 inch track 121/2.52 = 48
They are probaby selling 7 tooth 3" pitch drivers which I think fall somwhere between 8 and 9 tooth standard drivers. This way the stock track adjustment should work (no extensions or skid relocate)
tk
FastAction
I beleive the maverick was on the apex prototype. Its part paddle and part finger track.
- 43K
