Spark plugs .004 wider gap.
Skydog
Byron, IL
Well put new plugs in today the old ones had 2,500 miles on them with about 5 bottles of NOS and 1,200 miles a 12 psi. Does it sound right for the gap to be about .004 bigger for that kind of miles? Or do i have a little deto going on? Plugs looked great! Nice and tan. :Rockon:
Skydog
I think it would be cool if you kept track of your compression numbers and told us, since you are running 12 psi on pump gas!
lOOK AT THE PLUGS UNDER THE GLASS LOOKING FOR VERY SMALL LIGHTER SPECS.... SEE SPECS AND YOU HAVE DETNOATION...
06 Apex GT with .062 shim added thats a total of aprox .079 worth of gasket which takes compression from 11.8 to 9.3:1 and cranking compression to 165 lbs. Running 10 lbs. of boost on 93 octane pump gas. leak down is 3-4% looks to be safe. Supercharged feels strong :D
