TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Yup it can rub. Very common and doesnt seem to hurt anything. If you take a magnet out be sure to put it back in same way. Polarity matters. They are just pushed in there.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
Anyway you can tell which way? One came out when I pulled the shaft. So not sure exactly. Thanks for the info.
If I remember right it was all are in same way. So use a screwdriver to check the rest and make the one that came out the same.Anyway you can tell which way? One came out when I pulled the shaft. So not sure exactly. Thanks for the info.
TURBLUE
- Nov 1, 2005
- Southern Alberta
- Sidewinder MTX
So I checked it with another magnet and they are different. One attracts the next repels and so on. At least that how mine is.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Interesting.....that could very well be how the "speedo" picks up from it. Instead of a gear like apex used to have.So I checked it with another magnet and they are different. One attracts the next repels and so on. At least that how mine is.
Yes that’s what they do. Turbo I wasn’t sure the pattern but knew polarity was important. I bet you got it right.
Is it for sure that the magnets are staggered north/south? So 4 face in and 4 face out?So I checked it with another magnet and they are different. One attracts the next repels and so on. At least that how mine is.
YesIs it for sure that the magnets are staggered north/south? So 4 face in and 4 face out?
