upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
I had to change my chain case cover last year because drive shaft wore through…cleaned up magnets reassembled and plugged into new speedo sensor that came with used cover and now everything on gauge works (rpm, alt, water temp ect) but speedo stays at 0. Was in there again this year and all magnets are there and I cleaned and dialectic greased all connections and speedo still showing 0… Would a reversed magnet cause this? Should I go back to original sensor? Anybody ever have this happen?
Are you sure its plugged in? Maybe the pick up is is bad.
upei93
- Apr 27, 2008
- Dalhousie, NB
Yup plugged in, cleaned and dialectic greased...gauge shows a 0 for mph...when it warms up I'll try putting old pick up on...thought maybe it might have something to do with magnets although rpm works fine.
RPMs are off the motor, the only thing that read off the magnet is the speed. It would be the sensor or the magnets.
upei93
- Apr 27, 2008
- Dalhousie, NB
That’s what I wasn’t sure about…thanks!!RPMs are off the motor, the only thing that read off the magnet is the speed. It would be the sensor or the magnets.
upei93
- Apr 27, 2008
- Dalhousie, NB
Finally got around to changing sensor and same thing...speedo reads zero...was in there last month and all the magnets are there and are magnetized...wouldn't think I'd have 2 bad sensors. Blew my track this weekend so I have to go back in there to replace track, any ideas what to check?
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Are your magnets in properly? I believe they are to be alternated plus and minus.
upei93
- Apr 27, 2008
- Dalhousie, NB
I believe they were all the same...I will try that thx!!Are your magnets in properly? I believe they are to be alternated plus and minus.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Wow, this I did not realize... My Speedo is working, but I can't believe I was lucky enough to get them in the correct polarity when I replaced my driveshaft last year. It would be nice if the magnets were marked or something....Are your magnets in properly? I believe they are to be alternated plus and minus.
upei93
- Apr 27, 2008
- Dalhousie, NB
