Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
Are you guys spraying inside of the rubber boots too? I'd really like to know where it's actually coming from. But I just spray everything I can, including inside the boots.
Pstn head
Yup inside the boots, both boots on each side. Plus the steering shaft bushing up by the handle bars.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Where do you buy it?View attachment 144987
This is what I use it’s awesome spray all my joints never had a squeak.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I get it from we’re I work at a GM dealership. I will ask them tomorrow we’re they get it and let you know.Where do you buy it?
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I asked they order it from co-auto, from what they told me you have to be a dealer and order by the case. You can try a local GM dealer and see If this helps any.Where do you buy it?
Pan
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Bump, any other miracle spray or even better a solution that last more then a ride? Sway bar bushing noise is only prevalent in warmer big moguls trails. When cold I don't hear it so I think I did a good job with my multitude of different sprays. Then on the same ride coming back in warmer weather the trails are shot so squeak comes back to tell you not to ride in these condition. lol
stgdz
- Mar 27, 2021
- Buffalo MN
Mainway Solutions | Snowmobile Greasable Suspension Parts
Skidoo Suspension Parts, Snowmobile Suspensions, Snowmobile Parts, Arctic Cat Suspension Parts, Yamaha Suspension Parts, Ski-Doo Suspension Parts
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
What he said. Greaseable bushing setsMainway Solutions | Snowmobile Greasable Suspension Parts
Skidoo Suspension Parts, Snowmobile Suspensions, Snowmobile Parts, Arctic Cat Suspension Parts, Yamaha Suspension Parts, Ski-Doo Suspension Partsmainwaysolutions.ca
Snowaddict
- Feb 28, 2005
- Menasha, WI
- mstahl88
I'm still using Fluid Film as my go to. Depending on conditions, it may last one ride or more before the squeak returns.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Permatex Teflon spray! Sprayed the sway bay bushings a year ago still no squeak! 16 viper same thing ,lasts awhile!
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
X3 main way is the way to goMainway Solutions | Snowmobile Greasable Suspension Parts
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Its likely the a-arm bushings, where they attach at the bulkhead. The factory ones dry out fast.
Call Val at Mainway and get the greasable bushing kit. Works great
MS
MS
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
I put the Mainway kit in right after Val released it, that was like 3 seasons ago and I have not had one squeak since.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Either it went away or I GOT OLDER & CANT HEAR IT ANYMORE?
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
You guys with Mainway greasable bushings. Your saying your sway bar bushing doesn't squeak?
