Robs06attak
- Jan 9, 2016
- ontario
- 2006 apex attak and 2001 srx
I just order 1 and was wondering how many pics I should run in this and how long? I mainly run rivers and groomed trails
mikextx
- Feb 19, 2017
- holland MI
- 2017 apex xtx
- Holland MI
All of them
Robs06attak
- Jan 9, 2016
- ontario
Lol not good enough, would you run the 1.075 or go a bit longer? Also how many would you recommend?All of them
yamadooman
- Jan 16, 2005
- New Prague, MN
- 2023 SRX
minimum I would run is a 1.175 and I would lean towards a 1.325.. I would run at least 168 if not 192.. Good luck !
I saw a picture somewhere today that shows the track of the new SRX. It looked like it has the pattern showing, I would just use that. No need to measure or use template, just drill where all the markers are. It showed a combination of singles and doubles.I just order 1 and was wondering how many pics I should run in this and how long? I mainly run rivers and groomed trails
bleedyamaha
- Sep 28, 2013
- Northern Iowa
Did you notice if there were quiet bumps on the inside? I am guessing none.
POWERHAULIC
I was hoping none, but the pics that were posted here show quiet bumps and stud markers as wellDid you notice if there were quiet bumps on the inside? I am guessing none.
sledding rocks
- Feb 11, 2017
- north
- sidewinder
can anyone confirm if yamaha is using the ripsaw 1 quit track ? i have never used this track personally , i have always used the ripsaw 2 track which does not have the quit little bumps on the track , can anyone explain the difference of these 2 tracks ? is one better then the other ?
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Is a silent drive really silent compared to a full clip regular ripsaw2?
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
It will be a ripsaw 2 - 1" fully clipped and I'm sure it will have the quiet pads
POWERHAULIC
As listed the rip II even in 1" version is listed as quiet lug in my catalogsIs a silent drive really silent compared to a full clip regular ripsaw2?
Not a heck of a lot of difference in noise from the ones i have seen
POWERHAULIC
I hope that is a Rip II as the belting is better IMHO than Rip I, and the paddles are stifferIt will be a ripsaw 2 - 1" fully clipped and I'm sure it will have the quiet pads
sledding rocks
- Feb 11, 2017
- north
- sidewinder
to me looking at the pictures it sure looks like the ripsaw 1 , can anyone explain whats with the quiet pads ? anyone I talk to says it does nothing , also talked to Yamaha dealers and they also say they don't understand the purpose of the quiet pads either .It will be a ripsaw 2 - 1" fully clipped and I'm sure it will have the quiet pads
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
to me looking at the pictures it sure looks like the ripsaw 1 , can anyone explain whats with the quiet pads ? anyone I talk to says it does nothing , also talked to Yamaha dealers and they also say they don't understand the purpose of the quiet pads either .![]()
Makes the track quieter. Ride a sled without that track and you will see(hear). Might actually even be better for top speeds, who knows. At every row of lugs there is a fiberglass rod in the track, the idler weels make noise when they hit this rod, and it makes a noise/hum. The quiet pads are like little ramps before this rod, so there is less of an impact when the idler wheel goes over it. If a Yamaha dealer doesnt understand something as simple as that, not sure if they should be in the snowmbobile business.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Every magazine test rider says rip 1. Pic is a rip 1. So i believe its a rip 1.
I think this is a mistake, not the 1'' track I would prefer. Poor choice from Yamacat.
Swap to a rip 2 - 1" without the bumps.....
Dan
Dan
