RtxViper
- Feb 24, 2007
- Deerfield, Wisconsin
- 2019 SRX LE
After seeing the release today and in the market for a new sled i am thinking of going for the srx. Issue is the 1" track is useless to me as i ride a lot of groomed trail but want to be able to go in the deep snow. I am new to this pro cross chassis as i have owned 2 apexes over the last 10 years. I can't stand the le colors so i think my option is to get an srx and swap the track question is can i run any size track lug with this? i am considering a 1.38- 1.5" track to put on it and what length studs would i be able to run?
POWERHAULIC
yes you can use a 1.5 track, no problem.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Take a look at the Camso Storm 150. It's a mix between a 1.25 (outside lugs) and 1.5 (inside lugs). It hooks really good, top end speed will be better than a Cobra 1.352" lug height and is 2 ply and can be studded.
RtxViper
- Feb 24, 2007
- 2019 SRX LE
now this sounds like good idea i will look into this thanks!
sneakattak88
So Allan with the lower SRX you think we can still put in a 150?IF SO sweet,, im in!!!
