Stage 6 build
What did you do on the backside for air flow?
Dave from Turbor said he doesn't drill the bulkhead so neither did I. There's enough space between the intercooler and the bulkhead to allow air movement.
You have a pic?
Here’s the link for the pefi Intercooler has some pics. Looks very nice Doesn’t look as thick as turbors It would be nice to see some real data on IAT temps so see how effective they are. Seems like the limiting factor is the airflow with the design of the chassis with that small bulkhead directly behind it. I drilled mine out and opened up a window behind it to allow air to get thru.
I like the idea of a fan. Had one on my 2012 1100. Pulled air thru Intercooler seemed to help if anything it pushed air thru the engine bay and out the knee vents lowering under hood temps
Thank you. I did go the site, man that’s awful pricey
HAs a lot to do with quality of the core. Ive tried opening the bulk head behind it, made virtually no difference on data logs.
Seventh winter and I still love this thing!
Comparing logs from my last day out with the stock intercooler to today's with the Turbor intercooler, (similiar ambient temp), IATS are down 25 degrees or so. It'll be interesting once I can get a long pull in to compare with last year's IATS.
this is PFI inter cooler perfect fit, with all TURBO DYNAMIC stage 6 rnning 330 tune with adjustable waste gate timing.
What’s going on with the box above the gauge cluster there ?? Very interested!
I had no idea this existed! Similar to the dooooo dash box by the looks. Love that your GPS is mounted to it.
Not to hijack DMCTurbo thread look here..
