cookster
i have a set of heavy hitters i got from ulmer for my 05 rx-1, beleive it was a stage 2 weights ,helix,rollers, and springs. i am thinking of using the hitters in my 07 attack ,from what i have read i should leave the secondary alone and use the hitters only, was wondering what would be a good weight set up (07 attack , 162- 1.325 gold diggers in ripsaw, 240 lb rider) also have a set of heel clickers and helix and springs for the same rx-1 what would be a good set up for the 07 attack . if anyone could help me out with a set up that would be great. have used search to no end but mainly read super tip set ups
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
cookster, we have never sold Heavy Hitters. We have only sold the Super Tip weights in our clutch kits.
cookster
my bad, thought it was from you but i guess i forgot 2 years was awhile ago, sorry for the mistake. anyways snow is all gone maybe find out a base line for next year lt8r
For attak run
1/4 & 3/4 allen in heel
4.2 gram bolt & thick washer inner hole
4.2 gram bolt in tip
This will get you close
cookster
thanks turk
