fc8464
- Aug 4, 2014
- Fairbanks, Alaska
- 09 Summit
15 Viper MTX 153 blue/white
Thawing my Viper out today after Fridays ride and noticed steering boots full of ice to the point they where stretching the boot and couple of the retaining clips were missing. This is a flash back to my old Rev. Any one else noticed this or better yet whats the fix? Fred
Boostd
- Oct 18, 2014
- 2015 Viper MTN
I've noticed it as well, especially the last few weekends in the deep snow in Valdez. By the end of the day they were icebergs. no real fix other than a small mallet and break it up and push it out of boot and into engine bay. Lots of ice buildup as well underneath the radiator, lots!
Tomkat700
- Aug 20, 2014
- 2015 Viper MTX 153 T
I bought an extra Thumb screw for the exhaust side and that helps to keep the snow from finding it's way in, I have also heard of the Arctic cat guys running a bead of silicone around the boot. I haven't had any issues since I added the thumb screw but deep powder has been hard to come by this year.
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
I had this happen on my nytro, fixed it by putting pre-filter on every opening in and around the hood.
fiddlersgreen
- Feb 19, 2009
- Newfoundland...The Rock
- Viper xtx le
Mine is exactly the same.
Boots swelled up so much one side ripped.
swampcat
Boots are not the problem. Its the ill fitting body panels and poor Cat fit and finish. The large openings need to be Frogskinned.
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
fc8464
- Aug 4, 2014
- Fairbanks, Alaska
- 09 Summit
I thinck the biggest culprit is the louvered front above the radiator. Last ride the snow was just being pushed in there, But like Swampcat said seal every thing up. Might also try reversing the fan like Stingray had done.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Question, Are you guys that are having these issues ever thawing out you sled or is it always outside ?
fc8464
- Aug 4, 2014
- Fairbanks, Alaska
- 09 Summit
I thaw mine out after every ride.
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
Did anyone check with the dealer and see if this was a common issue?
Mine swelled so much that they ripped. I checked with the dealer for warranty but they won't cover it.
loudelectronics
Frogskinz are great. Also tape up any seals in the plastic.
I was just looking at the top of that boot where it meets frame. There should be another of those removable rivets there. It's not a good seal so any snow or melt can run right down into boot. Maybe add another rivet or silicone it there for sure.
You guys probably know this but I never noticed the two unscreened vents on each side of nose are wide open. Got to be a bunch of snow that gets rammed through there in deep. I am going to stuff some of that air conditioner filter material in there.
ViperWaters
- Feb 1, 2019
- Wisconsin
- 2015 Yamaha Sr Viper LTX
Do you happen to know the part number of the boot? Mine ripped the other day and need some replacements. Hoping that they don’t cost to much
- 10K
