Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
Hey guys,
I have a 21 Thundercat and have had issues with the steering freezing up. I don't have the luxury of a heated garage. Have any of you had issues and found a fix for it?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
Park it in the sun clean out under hood snow etc never seen this before.
I have never had any issues on my 2017s or my 2020 SRX
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Put a hair dryer blowing air on the bell crank area.
I have had this issue.
Just installed the Mainway bell crank bushings and added a grease fitting.
NickatNight
- Jan 20, 2021
- Michigan
- 2022 Yamaha sidewinder Xtx LE
I find my 2018 holds a lot of moisture from riding and I have had problems with frozen steering. I've had the steering freeze up twice not totally but enough to where I had to put both hands on one side of the bars and pull to get it to steer, lasts for about 10 miles even after a long warmup idle. I've had the throttle stick twice and I also get the code frequently for throttle position in the morning. My relays freeze too so on my 22 I'm upgrading to the frost free relays. These problems weren't every time. Mainly after getting a lot of moisture or snow under hood and then parking at the hotel over night. Might pack a cheap hair dryer and and extension cord in the toolbox from now on. (wouldn't do me any good on our cross country trips) Like I said I hope things are different on the 22's
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
Right, I usually ride with a group of guys and I rarely lead. If I follow them to supper or whatnot, when we come back out to ride, my handlebars will stick and usually stay like that until I can thaw it out or pull the boots off and get all the ice out of the nose. I've never had an issue with starting or reverse.I find my 2018 holds a lot of moisture from riding and I have had problems with frozen steering. I've had the steering freeze up twice not totally but enough to where I had to put both hands on one side of the bars and pull to get it to steer, lasts for about 10 miles even after a long warmup idle. I've had the throttle stick twice and I also get the code frequently for throttle position in the morning. My relays freeze too so on my 22 I'm upgrading to the frost free relays. These problems weren't every time. Mainly after getting a lot of moisture or snow under hood and then parking at the hotel over night. Might pack a cheap hair dryer and and extension cord in the toolbox from now on. (wouldn't do me any good on our cross country trips) Like I said I hope things are different on the 22's
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
We've had it happen in our group to a couple sleds. I now pull the boots yearly and soak the steering knuckles with fluid film. Haven't had the issue on ours when doing that.
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
Awesome. That's what I ended up doing at the end of last year but never got a chance to ride it much after. I figured now would be the time to fix it before riding season gets here. Hopefully it'll be good to go this year!We've had it happen in our group to a couple sleds. I now pull the boots yearly and soak the steering knuckles with fluid film. Haven't had the issue on ours when doing that.
