beeze455
- Nov 23, 2010
- Bowdoinham, ME
- www.gopherdesign.com
Have you tested or bought a new raditor cap? Have you tested the pressure of the system while it is running?
Drilling holes by the instument panel\vent kit, water wetter, extra cooler, turning the fan on earlier, different thermostat, drilling a hole in the thermostat, engine ice, ice scratchers, running studs, pissing on your engine at every stop are all items that will keep your engine cooler. I would not do many of these and dont think you should bother yet because you have a problem.
I bet your system is not building pressure.
Do you have a pressure tester?
Buy something like http://www.amazon.com/Mityvac-MV4560-Ra ... ure+tester
Hook the unit up and pressure it up and run the engine and see what happens.
