Storage Bags. Windshield/handlebar/gas tank.
milletime11
Age
37
Temperance
2011 Nytro XTX
Since the Yamaha windshield bag, tank bag, and handle bar bags are no longer being made. Has anyone found anything that works well and fits in these locations?
Skins, powermadd
Arctic cat/ Sr Viper belt bag, riveted to tank cover. Holds a pair of 20oz. Bottles.
I put the Viper handlebar bag on my Nytro XTX. Needed to remove the black plastic tuning fork cover from the bars to get it to fit.
Can you upload a picture? Like to check it out.
I see you have an XTX. This is my 08' RTX stretched to 144" which should have the same length tunnel as your XTX. I made a simple heat shield out of 3/16'-1/4" aluminum that I bent in a vise with wood and a hammer. I cut the shape with a jig saw. The heat shield is bolted to the top of the tunnel with 2 M6 bolts and nuts. This works great with the exhaust turn out and a Skinz tunnel bag. This bag is not cheap but roomy and it has elastic string around it so you can cinch it up when you dont have much in it. The rear of the bag sits ontop of the tail lamp housing but you can still see the TL from behind the sled. Love this set up and it has worked great the past 3,000 miles since I added it. This picture was taken when I first mocked it up and before I riveted on the buckles. G.B.
Enough room to fit a pair of goggles but that’s about it.
