SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Is bearing on stub shaft supposed to be flush? Cause mine isn't. I can get a .040 feeler guage between housing and bearing.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Should be tight to the housingIs bearing on stub shaft supposed to be flush? Cause mine isn't. I can get a .040 feeler guage between housing and bearing.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Yes it should be flush. Mine was the same. Threw it in my press and it took a fair bit of force to get it flush. Have you blown a few belts at high speeds?Is bearing on stub shaft supposed to be flush? Cause mine isn't. I can get a .040 feeler guage between housing and bearing.
SideHogger
- Apr 16, 2016
- upstate ny
Just 2 in 4000 miles but excessive heat in secondary but just pulled primary and I found large gap. I switched to ultimax and caught it and secondary ready to let go. Can get 1000 miles to a belt but looking to get better!Yes it should be flush. Mine was the same. Threw it in my press and it took a fair bit of force to get it flush. Have you blown a few belts at high speeds?
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Guys are we all talking about the same thing? There is a small gap on brand-new, out of the box stub shaft assemblies. The first picture below is a brand-new one. The second picture is my old one.
Here's the thread where I posted this info along with some other views: https://ty4stroke.com/threads/blew-...2-xs825-belts-gone-in-160-miles.159869/page-6, #82
The stub shaft bearing outer surface is usually what moves in the stub shaft retaining collar. If you look at the lower pic of the used assemble you can see a bit of a gap.
If you press the bearing and shaft out of the outer collar, coat the outer bearing surface with green bearing retention Loctite, then press the whole assembly in the ring until it bottoms out, you should be good to go.
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
So, is the brand new one (pictured above in post #20) I took out of the box not set correctly? I've only seen two in my life--the old assembly I removed, and the new one I unboxed. I don't have any other frame of reference, but I'm guessing (hoping) the new one out-of-the-box was pressed correctly by the factory, and it has a gap.
Its so hard to tell from pics. If you don't have a hydraulic press, I would bring it to a machine shop and ask them to confirm the bearing is seated. A friend on mine with a tuned Winder was blowing 8JP belts every few hundred miles so I had him remove and bring me his stub shaft assembly. When I put his stub shaft in my hydraulic press the bearing moved almost .040" in the collar. I think they all need to be checked.
apexhank
- Mar 5, 2011
- HUDSON FALLS AND BIG MOOSE LAKE, NY
- 2021 SIDEWINDER LTX GT (soon)!
2019 SIDEWNDER LTX DX 6000 miles
2018 VIPER LTX DX 2200 miles
2014 VIPER LTX DX 8000 + miles
2014 BENNINGTON 22 ft. PONTOON BOAT/ 90 HP Yamaha
Does anyone have the part number for the Yamaha clutch puller?
Hank
Hank
EPI Perfomance .com
PCP-6
Is the one I have used for years
PCP-6
The housing has a relief cut into it on the side enabling 0 clearance for the bearing to fully seat. Should be no gap.
SideHogger
- Apr 16, 2016
- upstate ny
Snowcaine, it looks from pictures that the new one has more of a gap than the old?
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
It’s the lighting. The old one has a visible concave slope inward from the outside portion of the bearing to the center of the bearing. There is a 1.5mm height difference between the old one and the new one sitting side by side. Photo of that is in the link I put in post #20. Will take some more pics today. I’m concerned if I have a brand-new out of the box unit that’s not correctly seated!
snowcaine
- Dec 23, 2019
- Indiana
- 20 Sidewinder
21 ZR 9000
23 SRX
Ok couple of things to note:
1. As I mentioned above, the only two stub shaft assemblies I've ever seen are the one I removed from my machine and the new one I unboxed from Yamaha. Both had a gap as shown in post #20 above. I intend to buy another assembly to toss on the shelf. When I get it, I'm very interested to see what kind of gap it has. If knowledgeable people like Cannondale say it should sit flush with no gap, then I'd trust that when disassembling/reassembling!
2. What I mentioned in post #28 regarding a concave slope inward from the outside portion of the bearing to the center of the bearing is shown with the following pictures. On my old stub shaft assembly, there is a 1.17 mm inward slope from the outside of the bearing seal to the inner portion of the bearing seal, and it is visually obvious in person. On my new stub shaft assembly, that surface is visually flat (I didn't measure it before I installed it, but it was visually flat).
3. For what it's worth, on my old stub shaft assembly, there is a 0.011" gap between the stub shaft collar and the bearing seating surface. I didn't measure the new one, but when I get my shelf unit, I'll measure that one to compare.
RAMSOMAIR
Mine got pushed in .040 after blowing a belt. Had it pushed back in a press and it is now seated all the way in, no gap
- 14K
