nytrose
I ride very aggresive trail and hv always run studs on the outer belts. I find I can come into a corner a lot faster and turn more confidently and power out a lot better....at least on my old sleds. Anyway now that i'm the proud owner of an 09 SE I only want to do this once,I think some of u have convinced me to go double backers for more durability which i think is great...... but i also want to stud the outside.
Do you think it would be wise to run for example 1.375 center doubles and install 1.325 in the outside belts for cornering,the idea being less stress on the outside belts during hard straight line acceleration.
LJ 452
Interesting thought. Though you will have to run 192 if you go with double backers, IMO too many. There’s no need for that many. I would forget about the outside belt, have you ridden a Nytro yet? Even the Mono transfers so well that you really don’t get a ton of sliding in the corners. Unless of course you set it up to do so.
nytrose
I haven't riden it yet
LJ 452
If your set on using doubles, then you may want to ride it first with either no studs or just the center belt done with the 144 double/single. Then if needed add the outer, which I don't think you'll require.
nytrose
thanks LJ anyone else??
NB-NYTRO
nytrose
is there a template for that pattern?
NB-NYTRO
Its one in the first pict I posted.
Yamadooed
- Dec 19, 2006
- Northern Illnoise
- 08 Nytro
05 Vector
09 TNT
02 MXZ
Run the woodys 144 single double pattern up the center if you find you want more after that its an easy upgrade to add the singles to the outer belt for a 192 pattern...
nytro23
studding
Got over 500 miles on my Roetin Hornets, some rocks andd gravel....best stud going
- 35K
