Swaybar update help???? 12 or 13 /??
TonyVT
Vermont
Website
fletcherroughriders.posterous.com
I want to update my swaybar on my 03 shorty.
1. Should I go with the 12 or the 13mm?
2.Can someone give me the run down on the complete parts I will need?
bar, square link (goes on bar end), round eye links, bushings?, bolts?
Tony
ps. please send snow to Vermont,, it sucks here!!! Who knew?????
I agree... 13mm... dont go half way... there is no disadvantage to the 13mm over a 12..
I'm new to Yamaha and don't pretend to know from experience but, somewhere on this site I thought I read that the 13mm bar might stiiffen up the ride more than the 12 mm. Is that true? I'm a girlie man and want soft ride. I'm just looking to reduce the inside ski lift. studdog
So now Im re thinking. I went to the Pioneer site and they say that adding the longer links to the standard 03 10mm bar will help with ski lift quite a bit. Sooooo.
I ride groomed trails 95% of the time. I ride semi agressive maybe 75% of the time. I do want to help my ski lift so when I push it I can go confidently. But I dont want to make it a harsh ride either... Keep in mind that I have completely stock suspension and intend to add the 5mm washers in back too.
Comments???
Re: ??
Comments???
What do you want to do??? Rail around corners or ride like a sally?? LOL
Quit jackin around and just get the 13mm bar and longer links..
My sled is having the 13mm bar fitted as we speak. I'll probably drop the front preload a few more turns as recommended by Pioneer (Ohlins) and see how it works.
My front end with the Ohlins was very compliant and controlled even on quite big hits, 3 clicks up from standard on the damping.
